メインコンテンツにスキップ
How to Rebuild a Briggs and Stratton Quantum Engine Carburetor
必要な工具と部品
  1. How to Rebuild a Briggs and Stratton Quantum Engine Carburetor, Remove the Air Filter Cover: 手順 1、 3の画像 1 How to Rebuild a Briggs and Stratton Quantum Engine Carburetor, Remove the Air Filter Cover: 手順 1、 3の画像 2 How to Rebuild a Briggs and Stratton Quantum Engine Carburetor, Remove the Air Filter Cover: 手順 1、 3の画像 3
    • The air filter and its cover are located to the right of the yellow warning label under the throttle cable.
    • Remove the single screw attaching the cover and filter using a 5/16'' socket.
    • Pull straight outward until the filter assembly is detached.
    • The screw is a flat head as well as a 5/16'' socket.
  2. How to Rebuild a Briggs and Stratton Quantum Engine Carburetor, Remove the throttle Cable: 手順 2、 1の画像 1
    • The throttle cable will be located above the air filter assembly.
    • Use a flathead screwdriver to remove the throttle cable.
    • If your engine is not equipped with a throttle, skip this step.
  3. How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 手順 3、 2の画像 1 How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 手順 3、 2の画像 2
    • Remove the backplate of the air filter assembly to access the carburetor.
    • Using a 5/16" socket, remove the three screws inside of the assembly.
  4. How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 手順 4、 3の画像 1 How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 手順 4、 3の画像 2 How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 手順 4、 3の画像 3
    • Remove the fuel line spring clamp with pliers.
    • Remove the fuel line from the carburetor by pulling directly outward.
    • Crimp the line with locking pliers. Do this before removing the fuel line to mitigate fuel spillage.
    • Drain the fuel line into a container and dispose of it properly.
  5. How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 手順 5、 2の画像 1 How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 手順 5、 2の画像 2
    • To remove the carburetor, use a 3/8" socket with an extension and ratchet to remove the two screws attached to the engine block.
    • Turn the carb 90 degrees, and pull off of the Z bend in the carb linkage.
  6. How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 手順 6、 3の画像 1 How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 手順 6、 3の画像 2 How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 手順 6、 3の画像 3
    • Remove the carburetor bowl screw with a 1/2" socket and ratchet.
    • Empty fuel from the carburetor bowl into a container for disposal.
  7. How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 手順 7、 3の画像 1 How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 手順 7、 3の画像 2 How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 手順 7、 3の画像 3
    • Spray the interior of the carburetor with carb cleaner.
    • Remove the float pin.
    • This will allow the float and needle to be removed as one piece.
    • This is not a full carburetor cleaning. This is just a rinse-off.
  8. How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 手順 8、 3の画像 1 How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 手順 8、 3の画像 2 How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 手順 8、 3の画像 3
    • Spray out the three major spots in the following order: the main adjustment hole, the inlet needle hole, and the main jet.
    • If the carb cleaner does not pass through any component, use a small piece of wire to poke through the passage.
    • If using a needle to clear passages, spray the passages with carb cleaner after clearing.
  9. How to Rebuild a Briggs and Stratton Quantum Engine Carburetor: 手順 9、 1の画像 1
    • After all parts are clean, lay them out to prepare for reassembly.
終わりに
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
Matthew Dunham
メンバー登録日: 03/24/21
166 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team S6-G8, Riel Spring 2021 UMass Dartmouth, Team S6-G8, Riel Spring 2021人のメンバー
UMASSD-RIEL-S21S6G8
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 54
過去 30 日: 276
今までの合計 5,669
