メインコンテンツにスキップ
How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster
必要な工具と部品
  1. How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster, How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: 手順 1、 1の画像 1
    • Remove all five 5mm Phillips #1 screws from the bottom of the toaster.
  2. How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: 手順 2、 1の画像 1
    • Lift the top of the toaster from the bottom section of the toaster.
    • Do this carefully so that you don't damage the switch board.
  3. How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: 手順 3、 1の画像 1
    • Look into the toaster and locate the two divots that the support bracket has detached from.
  4. How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: 手順 4、 2の画像 1 How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: 手順 4、 2の画像 2
    • Locate the detached support bracket.
    • From the back of the toaster (the side opposite the side of the toasting lever), you will see the broken support bracket sticking out.
  5. How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: 手順 5、 3の画像 1 How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: 手順 5、 3の画像 2 How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: 手順 5、 3の画像 3
    • Use the portion of the bracket that is sticking out of the back of the toaster to move the support bracket.
    • Align the support bracket with the two divots on the moving bracket assembly.
    • In this particular model, the shell of the toaster cannot be completely removed. It might be helpful to have a helper hold up the shell of the toaster so that it is not in your way.
  6. How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: 手順 6、 1の画像 1
    • Using moderate force, push the teeth of the support bracket into the divots on the moving bracket assembly.
    • If the teeth on the support bracket are damaged, further repair might be necessary in order for them to fit into the divots.
  7. How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: 手順 7、 2の画像 1 How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: 手順 7、 2の画像 2
    • Carefully lower the shell of the toaster back down to its base.
    • Lift and lower the toasting lever a few times to ensure that the support bracket is firmly in place.
  8. How to Reattach the Support Bracket in a Hamilton Beach 2-Slice Toaster: 手順 8、 1の画像 1
    • Screw on the bottom of the toaster using all five 5mm Phillips #1 screws.
終わりに
Follow these steps and your toaster will be as good as new!
作成者
1人の作成者と共同作成されました。
Tori Mobley
メンバー登録日: 02/20/18
157 ポイント
1ガイドが承認済み
チーム
University of Delaware, Team S10-G4, McGuire Spring 2018 University of Delaware, Team S10-G4, McGuire Spring 2018人のメンバー
UD-MCGUIRE-S18S10G4
3 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 33
今までの合計 2,370
