メインコンテンツにスキップ
How to Reattach the Head of a Mailbox to the Base
必要な工具と部品
  1. How to Reattach the Head of a Mailbox to the Base, How to Reattach the Head of a Mailbox to the Base: 手順 1、 2の画像 1 How to Reattach the Head of a Mailbox to the Base, How to Reattach the Head of a Mailbox to the Base: 手順 1、 2の画像 2
    • Inspect the head of the mailbox to see where the detachment is located.
  2. How to Reattach the Head of a Mailbox to the Base: 手順 2、 2の画像 1 How to Reattach the Head of a Mailbox to the Base: 手順 2、 2の画像 2
    • Gather all materials needed.
    • Adhesive can be included depending on the tight fit you desire.
  3. How to Reattach the Head of a Mailbox to the Base: 手順 3、 3の画像 1 How to Reattach the Head of a Mailbox to the Base: 手順 3、 3の画像 2 How to Reattach the Head of a Mailbox to the Base: 手順 3、 3の画像 3
    • Measure out the wood plank to match the length and width of the mailbox head.
  4. How to Reattach the Head of a Mailbox to the Base: 手順 4、 3の画像 1 How to Reattach the Head of a Mailbox to the Base: 手順 4、 3の画像 2 How to Reattach the Head of a Mailbox to the Base: 手順 4、 3の画像 3
    • Use a hammer or mallet to nail this wood plank to the bottom of mailbox head. Use at least four nails for this task.
    • Use gloves, if deemed necessary!
  5. How to Reattach the Head of a Mailbox to the Base: 手順 5、 2の画像 1 How to Reattach the Head of a Mailbox to the Base: 手順 5、 2の画像 2
    • Screw the sides down for a stronger fit using at least four screws.
  6. How to Reattach the Head of a Mailbox to the Base: 手順 6、 1の画像 1
    • Align the mailbox head back on the post.
  7. How to Reattach the Head of a Mailbox to the Base: 手順 7、 2の画像 1 How to Reattach the Head of a Mailbox to the Base: 手順 7、 2の画像 2
    • Hammer down the head to the post of the mailbox with at least three more nails.
    • Add adhesive if necessary for a sturdier attachment.
    • Since your hands are inside the mailbox, it may be best to use gloves for this task.
ゴール
作成者
1人の作成者と共同作成されました。
Terrell Cobbins
メンバー登録日: 03/21/23
145 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team M-3, Peters Spring 2023 University of Memphis, Team M-3, Peters Spring 2023人のメンバー
UM-PETERS-S23SMG3
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 18
今までの合計 184
