メインコンテンツにスキップ
How to Reattach a Broken Piece of Wood
必要な工具と部品
  1. How to Reattach a Broken Piece of Wood, How to Reattach a Broken Piece of Wood: 手順 1、 2の画像 1 How to Reattach a Broken Piece of Wood, How to Reattach a Broken Piece of Wood: 手順 1、 2の画像 2
    • Dust the surface of the fragment and the damaged area of the furniture.
    • Any household cleaner will work; we recommend a damp rag.
    • Clean carefully, making sure not to cause further damage by splintering the fragment.
  2. How to Reattach a Broken Piece of Wood: 手順 2、 2の画像 1 How to Reattach a Broken Piece of Wood: 手順 2、 2の画像 2
    • Check that the fragment fits well into the break in the furniture.
    • If the fragment does not fit perfectly, cut away any irregular slivers on the fragment using a utility knife to achieve as neat of a fit as possible.
  3. How to Reattach a Broken Piece of Wood: 手順 3、 3の画像 1 How to Reattach a Broken Piece of Wood: 手順 3、 3の画像 2 How to Reattach a Broken Piece of Wood: 手順 3、 3の画像 3
    • Apply glue to both the fragment and the furniture.
    • Check that the glue is spread evenly throughout both pieces.
    • Using a brush to spread the glue to all crevices is most effective.
  4. How to Reattach a Broken Piece of Wood: 手順 4、 2の画像 1 How to Reattach a Broken Piece of Wood: 手順 4、 2の画像 2
    • Insert the wood fragment into the glued spot on the furniture.
  5. How to Reattach a Broken Piece of Wood: 手順 5、 2の画像 1 How to Reattach a Broken Piece of Wood: 手順 5、 2の画像 2
    • Wipe away any excess glue using a damp rag.
    • Be careful not to move the fragment out of alignment as you are wiping.
  6. How to Reattach a Broken Piece of Wood: 手順 6、 2の画像 1 How to Reattach a Broken Piece of Wood: 手順 6、 2の画像 2
    • Clamp the two pieces together.
    • You can use any type of clamp that you have on hand. If you don't have a clamp, any type of clip would work.
    • Wait 30 minutes for the glue to dry before removing the clamp.
    • Be careful not to bump the fragment out of alignment as you are clamping.
終わりに
Continue using furniture as you had before!
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Zen Miller
メンバー登録日: 09/19/16
165 ポイント
1ガイドが承認済み
3件のガイドコメント
Thank you for the post. It will help me with the leg if a cigar table. However, a piece of wood broke off the front of my mom’s cedar chest and I won’t be able to use a clamp. What do you recommend?
Amanda - 返信
The clean and modern design of our products allows you to use the items for years. we are starting to sale small products and want to get your feedback for these products. We are not the World best online store but we want to be and this is only possible with your response and recommendation.
anita.6j - 返信
Very easy to follow instructions. I've found the most difficult part of any fence build is getting the posts lined up properly and getting them plumb. Even with a line, it can be tough . https://www.whitewooden.com/
White Wooden - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 58
今までの合計 19,320
