メインコンテンツにスキップ
How to Reattach a Backpack Grab Handle
必要な工具と部品
  1. How to Reattach a Backpack Grab Handle, How to Reattach a Backpack Grab Handle: 手順 1、 3の画像 1 How to Reattach a Backpack Grab Handle, How to Reattach a Backpack Grab Handle: 手順 1、 3の画像 2 How to Reattach a Backpack Grab Handle, How to Reattach a Backpack Grab Handle: 手順 1、 3の画像 3
    • Use a pair of scissors to open the seam on the backpack where the grab handle was torn off.
    • Caution: Be careful when using scissors this way.
  2. How to Reattach a Backpack Grab Handle: 手順 2、 2の画像 1 How to Reattach a Backpack Grab Handle: 手順 2、 2の画像 2
    • Open up the inner seam at the same spot using a pair of scissors.
  3. How to Reattach a Backpack Grab Handle: 手順 3、 2の画像 1 How to Reattach a Backpack Grab Handle: 手順 3、 2の画像 2
    • Get your sewing needle and thread with a colour that matches the area on the backpack being repaired.
  4. How to Reattach a Backpack Grab Handle: 手順 4、 3の画像 1 How to Reattach a Backpack Grab Handle: 手順 4、 3の画像 2 How to Reattach a Backpack Grab Handle: 手順 4、 3の画像 3
    • Thread your sewing needle.
    • Make sure your thread is doubled; this makes it more durable and less likely for your stitching to come apart.
  5. How to Reattach a Backpack Grab Handle: 手順 5、 3の画像 1 How to Reattach a Backpack Grab Handle: 手順 5、 3の画像 2 How to Reattach a Backpack Grab Handle: 手順 5、 3の画像 3
    • Hold the edge of your grab handle down at the the first seam you opened.
    • Use the threaded needle to stitch the end of the handle to that spot, then cut off the thread and tie it into a knot.
    • Caution: Sewing needles are sharp; be careful not to poke yourself.
    • This repair only requires one of these two basic stitching methods.
  6. How to Reattach a Backpack Grab Handle: 手順 6、 2の画像 1 How to Reattach a Backpack Grab Handle: 手順 6、 2の画像 2
    • Hold down the second seam you opened, over the reattached grab handle, and stitch it closed.
    • Use one of these basic stitching methods.
  7. How to Reattach a Backpack Grab Handle: 手順 7、 3の画像 1 How to Reattach a Backpack Grab Handle: 手順 7、 3の画像 2 How to Reattach a Backpack Grab Handle: 手順 7、 3の画像 3
    • Cut off the remaining thread and tie it into a knot.
終わりに
Once you have completed this guide, you will be able to make use of your grab handle once again.
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Onyinyechi Onyeagucha
メンバー登録日: 01/19/21
306 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G20, Woodhouse Winter 2021 York University, Team S1-G20, Woodhouse Winter 2021人のメンバー
YORK-WOODHOUSE-W21S1G20
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 44
過去 30 日: 213
今までの合計 6,804
