メインコンテンツにスキップ
How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner
必要な工具と部品
  1. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner, How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 1、 2の画像 1 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner, How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 1、 2の画像 2
    • The leather door lining is loose.
  2. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner, Remove plastic trim: 手順 2、 3の画像 1 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner, Remove plastic trim: 手順 2、 3の画像 2 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner, Remove plastic trim: 手順 2、 3の画像 3
    • Using a plastic pry tool, carefully pry off the mock wood trim.
    • The mock wood trim tends to crack easily.
  3. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 3、 3の画像 1 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 3、 3の画像 2 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 3、 3の画像 3
    • If any of the plastic clips come loose with the trim, remove them and press them back into the door panel.
  4. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 4、 2の画像 1 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 4、 2の画像 2
    • Using a T20 Torx, remove the three screws located behind the previously removed trim.
  5. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 5、 3の画像 1 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 5、 3の画像 2 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 5、 3の画像 3
    • Using your plastic pry tool, pry the door panel loose, beginning along the bottom edge and moving up each side.
    • The door panel will still be attached at the top.
  6. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 6、 1の画像 1
    • Pull the door panel straight out along the top edge.
    • There is a series of metal clips that will pop lose.
    • When re-installing the door panel, it is important to line these clips back up with their respective holes on the door panel.
  7. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 7、 2の画像 1 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 7、 2の画像 2
    • Unclip the internal door handle mechanism inside the door handle by rotating clockwise.
  8. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 8、 1の画像 1
    • Unplug the speaker wire by pulling it straight out.
  9. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 9、 3の画像 1 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 9、 3の画像 2 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 9、 3の画像 3
    • Unplug the control panel wire by rotating the lever that is built into the plug.
    • Rotate the lever from the wire side down towards the door panel.
  10. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 10、 3の画像 1 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 10、 3の画像 2 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 10、 3の画像 3
    • Pop the light out of the bottom of the door panel and then unplug it.
  11. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 11、 2の画像 1 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 11、 2の画像 2
    • Now that the door panel is free from the car, move it to a flat workspace.
    • Apply a line of glue along the top edge and under the middle of the leather liner.
    • Have your clamps and wood spacers ready before applying glue.
  12. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 12、 2の画像 1 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 12、 2の画像 2
    • Push the liner into place in between the door panel sections.
  13. How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 13、 3の画像 1 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 13、 3の画像 2 How to Reattach a 2005-2013 BMW 3 Series Door Panel Liner: 手順 13、 3の画像 3
    • Using several clamps and pieces of wood (to distribute pressure), clamp the liner down to the door panel.
    • You may need to add larger pieces of wood on the inside of the door panel as spacers.
終わりに
Allow the glue to dry following the instructions on the tube. Reassemble the door following these instructions in reverse order.
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Sam A McDaniel
メンバー登録日: 09/16/20
298 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team S1-G13, Bishop Fall 2020 University of Memphis, Team S1-G13, Bishop Fall 2020人のメンバー
UM-BISHOP-F20S1G13
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 94
今までの合計 5,055
