メインコンテンツにスキップ
How to Reassemble the Palm IIIc
必要な工具と部品
  1. How to Reassemble the Palm IIIc, How to Reassemble the Palm IIIc: 手順 1、 1の画像 1
    • Reinsert the screen into the case that contains the buttons.
  2. How to Reassemble the Palm IIIc: 手順 2、 1の画像 1
    • Put the Motherboard back into casing from right to left.
    • Make sure the black clips are securing the motherboard into the casing.
  3. How to Reassemble the Palm IIIc: 手順 3、 3の画像 1 How to Reassemble the Palm IIIc: 手順 3、 3の画像 2 How to Reassemble the Palm IIIc: 手順 3、 3の画像 3
    • Secure the bottom two ZIF connectors into their slots by opening the flap and inserting the ZIF connectors.
    • Gently press down on the flap to secure the ZIF connector. This secures the screen and buttons to the motherboard.
  4. How to Reassemble the Palm IIIc: 手順 4、 2の画像 1 How to Reassemble the Palm IIIc: 手順 4、 2の画像 2
    • Connect the blue and red screen cables to the beige box they were removed from.
  5. How to Reassemble the Palm IIIc: 手順 5、 2の画像 1 How to Reassemble the Palm IIIc: 手順 5、 2の画像 2
    • Open the ZIF connector box at the top of the motherboard by gently pulling up on the flap.
    • Insert the ZIF tab into the connector box.
    • Gently press down on the flap to secure the ZIF tab in place.
  6. How to Reassemble the Palm IIIc: 手順 6、 1の画像 1
    • Attach the white box on the end of the red cable connected to the battery into the connector box on the motherboard.
  7. How to Reassemble the Palm IIIc: 手順 7、 1の画像 1
    • Place the front and back covers around the casing containing the motherboard and screen.
    • Before securing the covers, place the sensor in between the front and back cover at the top of the device.
    • After the sensor is in place between the two covers, firmly secure the front and back covers.
  8. How to Reassemble the Palm IIIc: 手順 8、 1の画像 1
    • Replace the long screws at the top of the back case with the Philips head screwdriver.
    • Replace the short screws to the bottom of the back case using the Philips head screwdriver.
    • After the screws are in place, insert the stylus.
  9. How to Reassemble the Palm IIIc: 手順 9、 1の画像 1
    • Gently snap the flip cover back into place where it connects at the top of the Palm IIIc
ゴール
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Angela Arthur
メンバー登録日: 02/16/12
101 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 1-5, Buehl Winter 2012 Ohio State, Team 1-5, Buehl Winter 2012人のメンバー
OSU-BUEHL-W12S1G5
5 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 318
