メインコンテンツにスキップ
How to Re-caulk a Bathroom
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
  1. How to Re-caulk a Bathroom, How to Re-caulk a Bathroom: 手順 1、 1の画像 1
    • Use a knife to uproot the old caulk that is sealed to the wall.
  2. How to Re-caulk a Bathroom: 手順 2、 1の画像 1
    • Peel off until all of the caulk is removed.
  3. How to Re-caulk a Bathroom: 手順 3、 1の画像 1
    • Remove all of the residual caulk that lies under the main slabs that were just pulled off.
    • Do this by angling the tip of the blade into the pivot and scraping up the caulk that lies there.
  4. How to Re-caulk a Bathroom: 手順 4、 3の画像 1 How to Re-caulk a Bathroom: 手順 4、 3の画像 2 How to Re-caulk a Bathroom: 手順 4、 3の画像 3
    • Before applying the new caulk, clean the area with hydrogen peroxide or rubbing alcohol.
    • Let the area dry for about 10 minutes before applying the new caulk. This will allow the new caulk to seal properly.
  5. How to Re-caulk a Bathroom: 手順 5、 2の画像 1 How to Re-caulk a Bathroom: 手順 5、 2の画像 2
    • Place the tip of the new bottle of caulk into the hole by the trigger.
    • Squeeze the trigger to cut.
  6. How to Re-caulk a Bathroom: 手順 6、 2の画像 1 How to Re-caulk a Bathroom: 手順 6、 2の画像 2
    • Use something sharp to break the inner seal of the caulk.
    • The use of the pin on the caulking gun (as shown in the 2nd picture) is an alternative to using a blade.
  7. How to Re-caulk a Bathroom: 手順 7、 2の画像 1 How to Re-caulk a Bathroom: 手順 7、 2の画像 2
    • Push the silver button and pull the spring back to fully open the chamber of the caulking gun.
    • Place the new bottle of caulk into the open chamber.
  8. How to Re-caulk a Bathroom: 手順 8、 2の画像 1 How to Re-caulk a Bathroom: 手順 8、 2の画像 2
    • To apply the new caulk, press the trigger and drag the gun across the area being re-caulked.
    • When caulking the area, try to use the appropriate amount of caulk. More is better than less.
  9. How to Re-caulk a Bathroom: 手順 9、 3の画像 1 How to Re-caulk a Bathroom: 手順 9、 3の画像 2 How to Re-caulk a Bathroom: 手順 9、 3の画像 3
    • After applying the new caulk, dab a finger in water and smooth it out.
    • The more times you smooth it out, the more caulk you take off. This is why using more is better than using less.
    • It takes 24 hours for new caulking to dry. DO NOT get the surface wet during this time. It will ruin your work.
終わりに
By using these tools and referring to this guide, you can re-caulk any part of your bathroom with relative ease.
5 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Nicholas Khorshidi
メンバー登録日: 09/29/15
353 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 10-2, Green Fall 2015 Cal Poly, Team 10-2, Green Fall 2015人のメンバー
CPSU-GREEN-F15S10G2
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 537
