1. Find the power cord.
    • Find the power cord.
    • Make sure that it is unplugged from the outlet. This is to make sure that no power is flowing through and you are not injured.
  2. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  3. Check to make sure that the power cord is connected to the device. If it is not connect the smaller end to the back of the device.
    • Check to make sure that the power cord is connected to the device. If it is not connect the smaller end to the back of the device.
  4. Check to make sure that the power cord is connected to an outlet. If not, take the two-pronged end and plug it in to an outlet. The device is now correctly plugged in.
    • Check to make sure that the power cord is connected to an outlet. If not, take the two-pronged end and plug it in to an outlet. The device is now correctly plugged in.
まとめ
Rosana Cheruvelil
メンバー登録日: 2012年09月26日
105 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 7-50, Forte Fall 2012 Cal Poly, Team 7-50, Forte Fall 2012人のメンバー
CPSU-FORTE-F12S7G50
5 メンバー
8のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 198
