メインコンテンツにスキップ
How to Pick Up a Dropped Stitch in Knitting
必要な工具と部品
  1. How to Pick Up a Dropped Stitch in Knitting, How to Pick Up a Dropped Stitch in Knitting: 手順 1、 1の画像 1
    • Locate the dropped stitch.
    • A dropped stitch is a loop of unsecured yarn, which means that no yarn is going through the loop.
  2. How to Pick Up a Dropped Stitch in Knitting: 手順 2、 2の画像 1 How to Pick Up a Dropped Stitch in Knitting: 手順 2、 2の画像 2
    • Insert the left needle through the loop of the dropped stitch.
    • You may use the right needle to grab the dropped stitch, but the dropped stitch must end on the left needle.
  3. How to Pick Up a Dropped Stitch in Knitting: 手順 3、 1の画像 1
    • Locate the bar of yarn behind the dropped stitch.
    • Depending on how many rows the stitch has unraveled, there may be multiple bars of yarn. If the stitch has unraveled more than one row, locate the bottom bar.
  4. How to Pick Up a Dropped Stitch in Knitting: 手順 4、 2の画像 1 How to Pick Up a Dropped Stitch in Knitting: 手順 4、 2の画像 2
    • Insert the right needle beneath the bottom bar of yarn and lift it onto the left needle.
  5. How to Pick Up a Dropped Stitch in Knitting: 手順 5、 2の画像 1 How to Pick Up a Dropped Stitch in Knitting: 手順 5、 2の画像 2
    • Use the tight needle to slip the dropped stitch over the bar of yarn.
  6. How to Pick Up a Dropped Stitch in Knitting: 手順 6、 3の画像 1 How to Pick Up a Dropped Stitch in Knitting: 手順 6、 3の画像 2 How to Pick Up a Dropped Stitch in Knitting: 手順 6、 3の画像 3
    • Repeat steps 3-5 for each row that the dropped stitch has unraveled.
  7. How to Pick Up a Dropped Stitch in Knitting: 手順 7、 1の画像 1
    • Once the dropped stitch has been picked up all the way to the current row, proceed in pattern.
終わりに
Your knitting project should now be fixed, and you can proceed with your work.
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Jillian Garcia
メンバー登録日: 09/28/22
175 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 1-6, Friess Fall 2022 University of North Texas, Team 1-6, Friess Fall 2022人のメンバー
UNT-FRIESS-F22S1G6
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 3
過去 30 日: 14
今までの合計 429
