メインコンテンツにスキップ
この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
How to Patch a Torn Window Screen
必要な工具と部品
  1. How to Patch a Torn Window Screen, How to Patch a Torn Window Screen: 手順 1、 1の画像 1
    • Remove the screen from the window frame and place it in your work space.
    • Removing the screen is not necessary but will make the fix easier. You can easily work through this fix with the screen on the frame as long as you can reach the tear from both sides of the screen.
  2. How to Patch a Torn Window Screen: 手順 2、 3の画像 1 How to Patch a Torn Window Screen: 手順 2、 3の画像 2 How to Patch a Torn Window Screen: 手順 2、 3の画像 3
    • From where the tear ends, measure one inch from the left, right, bottom, and top of the tear.
    • Make note of these measurements as they will be the required size of your patch.
  3. How to Patch a Torn Window Screen: 手順 3、 3の画像 1 How to Patch a Torn Window Screen: 手順 3、 3の画像 2 How to Patch a Torn Window Screen: 手順 3、 3の画像 3
    • Measure your patch using the dimensions determined in step 2.
    • If the patch is larger than said dimensions, mark where you will cut it.
  4. How to Patch a Torn Window Screen: 手順 4、 3の画像 1 How to Patch a Torn Window Screen: 手順 4、 3の画像 2 How to Patch a Torn Window Screen: 手順 4、 3の画像 3
    • Use scissors to cut the patch to size.
    • Place your patch over the tear to confirm it extends one inch from every side.
  5. How to Patch a Torn Window Screen: 手順 5、 2の画像 1 How to Patch a Torn Window Screen: 手順 5、 2の画像 2
    • Using the pliers or tweezers, remove some threads from two opposite sides of the patch.
    • Stop when approximately half an inch of threads are exposed on each side.
  6. How to Patch a Torn Window Screen: 手順 6、 2の画像 1 How to Patch a Torn Window Screen: 手順 6、 2の画像 2
    • Bend the exposed threads 90 degrees on both sides of the patch.
  7. How to Patch a Torn Window Screen: 手順 7、 3の画像 1 How to Patch a Torn Window Screen: 手順 7、 3の画像 2 How to Patch a Torn Window Screen: 手順 7、 3の画像 3
    • Use scissors to cut away the frayed sections of the tear.
  8. How to Patch a Torn Window Screen: 手順 8、 3の画像 1 How to Patch a Torn Window Screen: 手順 8、 3の画像 2 How to Patch a Torn Window Screen: 手順 8、 3の画像 3
    • Center the patch over the tear.
    • Press the exposed patch threads through the screen.
    • Try to keep the wires as even as possible. This will make the patch look nicer in the end.
  9. How to Patch a Torn Window Screen: 手順 9、 3の画像 1 How to Patch a Torn Window Screen: 手順 9、 3の画像 2 How to Patch a Torn Window Screen: 手順 9、 3の画像 3
    • Gently, but firmly, bend the threads back in the direction of the tear to secure the patch.
    • If you are working with a screen still on its frame, place one hand on the side with the patch, while using the other to bend the threads on the other side. This will ensure you do not break your screen by pushing only from one side.
    • Do this for both sides, making sure the patch does not move around when both sides have been bent.
  10. How to Patch a Torn Window Screen: 手順 10、 2の画像 1 How to Patch a Torn Window Screen: 手順 10、 2の画像 2
    • Check that the patch is secure and covers the tear well.
    • If the screen was removed from the frame, reinsert the screen back on the frame.
終わりに
Your window screen is now patched. Feel free to once again open your window and let the breeze in without any pesky bugs or debris flying through the tear!
作成者
4人の作成者と共同で作成されました。
Alexis
メンバー登録日: 10/26/17
149 ポイント
1ガイドが承認済み
チーム
DePaul University, Team S1-G1, Dush Fall 2017 DePaul University, Team S1-G1, Dush Fall 2017人のメンバー
DPU-DUSH-F17S1G1
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 19
今までの合計 1,481
