メインコンテンツにスキップ
How to Patch a Small Hole in Drywall
必要な工具と部品
  1. How to Patch a Small Hole in Drywall, How to Patch a Small Hole in Drywall: 手順 1、 3の画像 1 How to Patch a Small Hole in Drywall, How to Patch a Small Hole in Drywall: 手順 1、 3の画像 2 How to Patch a Small Hole in Drywall, How to Patch a Small Hole in Drywall: 手順 1、 3の画像 3
    • If the initial hole is smaller than a quarter, use a screwdriver to carefully make the hole larger. This will allow the patching plaster to fill better.
    • Place painter's tape around the hole so the plaster does not get onto places it does not belong.
  2. How to Patch a Small Hole in Drywall: 手順 2、 3の画像 1 How to Patch a Small Hole in Drywall: 手順 2、 3の画像 2 How to Patch a Small Hole in Drywall: 手順 2、 3の画像 3
    • Dip the chisel scraper into the patching plaster, and begin to fill the hole. Use a gentle pressing motion to fill. Press multiple layers of the plaster until the entire hole is filled.
    • Let the wall dry for at least three hours.
  3. How to Patch a Small Hole in Drywall: 手順 3、 2の画像 1 How to Patch a Small Hole in Drywall: 手順 3、 2の画像 2
    • After the filling is fully dry, take a damp sponge and gently remove any access plaster from the wall. First, start with the surface surrounding the hole.
    • After the wall is clean of excess plaster, carefully wipe the plaster from inside the wall until it is even with the original surface.
  4. How to Patch a Small Hole in Drywall: 手順 4、 3の画像 1 How to Patch a Small Hole in Drywall: 手順 4、 3の画像 2 How to Patch a Small Hole in Drywall: 手順 4、 3の画像 3
    • Remove the painters tape from the wall.
    • Dip the paint sponge in paint, and paint the wall with the original color of the wall.
    • Let it dry accordingly.
終わりに
Hopefully you found this guide easy and helpful for fixing any minor dents in your drywall. Good luck!
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Jessica Yurgin
メンバー登録日: 01/19/16
178 ポイント
1ガイドが承認済み
チーム
Oakland University, Team 6-1, Walwema Winter 2016 Oakland University, Team 6-1, Walwema Winter 2016人のメンバー
OAK-WALWEMA-W16S6G1
10 メンバー
13のガイドは作成済み
2件のガイドコメント
Great guide to fixing plasterboard. I normally just try to fit a scrap piece of plasterboard in the hole when fixing it, but using cardboard is a much easier and better idea. I can cut it with scissors and won't have to make the whole bigger to screw the piece of drywall in. If you need help with drywall repair in your home visit: https://www.plasterroanoke.com
Kim - 返信
Very nice… I really like your blog. Very useful information.
Century Drywall - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 36
今までの合計 5,847
