メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to Patch a Ripped Backpack
必要な工具と部品
  1. How to Patch a Ripped Backpack, Identify the repair area: 手順 1、 3の画像 1 How to Patch a Ripped Backpack, Identify the repair area: 手順 1、 3の画像 2 How to Patch a Ripped Backpack, Identify the repair area: 手順 1、 3の画像 3
    • Identify the defective area and assess how large the damage is.
    FixBotに聞いてみる
  2. How to Patch a Ripped Backpack, Prepare for patching: 手順 2、 3の画像 1 How to Patch a Ripped Backpack, Prepare for patching: 手順 2、 3の画像 2 How to Patch a Ripped Backpack, Prepare for patching: 手順 2、 3の画像 3
    • Use a pair of scissors to cut the loose threads and clean the area.
    • Use a similar color fabric to create your "own patch".
    • Tip: Cut a piece of fabric that is at least 1cm bigger than the tear (from each side). Use a sewing machine to create a hem around the border of the patch.
    FixBotに聞いてみる
  3. How to Patch a Ripped Backpack, Pin the area: 手順 3、 3の画像 1 How to Patch a Ripped Backpack, Pin the area: 手順 3、 3の画像 2 How to Patch a Ripped Backpack, Pin the area: 手順 3、 3の画像 3
    • Use sewing pins to pin the area and set the patch in place.
    • Start sewing follow the shape of the patch.
    FixBotに聞いてみる
  4. How to Patch a Ripped Backpack, Continue stitching: 手順 4、 3の画像 1 How to Patch a Ripped Backpack, Continue stitching: 手順 4、 3の画像 2 How to Patch a Ripped Backpack, Continue stitching: 手順 4、 3の画像 3
    • Once you have stitched the first side of the patch. Apply more sewing pins to set the patch in place and continue sewing.
    • Tip: In this example, a square patch was used to repair the tear. For aesthetic reasons, a “triangle” shape was achieved by inserting part of the patch inside the tear and folding one side inward.
    FixBotに聞いてみる
  5. How to Patch a Ripped Backpack, Finished and ready!: 手順 5、 3の画像 1 How to Patch a Ripped Backpack, Finished and ready!: 手順 5、 3の画像 2 How to Patch a Ripped Backpack, Finished and ready!: 手順 5、 3の画像 3
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
    FixBotに聞いてみる
終わりに
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
作成者
1人の作成者と共同作成されました。
Ben Blischke
メンバー登録日: 07/19/23
10,230 ポイント
68のガイドは作成済み
チーム
INTERSPORT INTERSPORT人のメンバー
Community
25 メンバー
172のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 52
今までの合計 814
