メインコンテンツにスキップ
How to Patch a Hole in a Plastic Trash Can
必要な工具と部品
  1. How to Patch a Hole in a Plastic Trash Can, How to Patch a Hole in a Plastic Trash Can: 手順 1、 3の画像 1 How to Patch a Hole in a Plastic Trash Can, How to Patch a Hole in a Plastic Trash Can: 手順 1、 3の画像 2 How to Patch a Hole in a Plastic Trash Can, How to Patch a Hole in a Plastic Trash Can: 手順 1、 3の画像 3
    • Remove any obstructions such as labels.
    • Wipe down your trash can to ensure there is no debris on the surface.
  2. How to Patch a Hole in a Plastic Trash Can: 手順 2、 2の画像 1 How to Patch a Hole in a Plastic Trash Can: 手順 2、 2の画像 2
    • Cut a piece of duct tape equal to the length of the cracks and/or holes on your trash can.
    • You may need more than one piece of tape if the damage is significant.
    • Place the duct tape on the inside where the damage is present.
  3. How to Patch a Hole in a Plastic Trash Can: 手順 3、 3の画像 1 How to Patch a Hole in a Plastic Trash Can: 手順 3、 3の画像 2 How to Patch a Hole in a Plastic Trash Can: 手順 3、 3の画像 3
    • This step deals with material that can be harmful if inhaled and/or it makes contact with your skin. It is with utmost importance that you wear proper PPE (personal protective equipment). Disposable gloves and an N95 face mask are highly recommended.
    • Follow the instructions on the back of the Bondo Short Strand Fiberglass Filler label for proper measurements of the filler.
    • Add in a sufficient amount of Bondo Cream Hardener according to the Bondo Fiberglass Filler label.
    • Mix together until this mixture becomes a single color.
  4. How to Patch a Hole in a Plastic Trash Can: 手順 4、 3の画像 1 How to Patch a Hole in a Plastic Trash Can: 手順 4、 3の画像 2 How to Patch a Hole in a Plastic Trash Can: 手順 4、 3の画像 3
    • Use a 1/2" plastic putty knife to apply the mixture to the outside of your trash can.
    • If the surface of your trash can is extremely smooth, sand the area around the damage before applying the mixture to allow it to adhere better to the surface.
    • This mixture will begin to harden within 3 to 4 minutes, so work as fast as you can to get an even layer on the surface.
    • Allow the mixture to cure on your trash can for at least 30 minutes.
  5. How to Patch a Hole in a Plastic Trash Can: 手順 5、 2の画像 1 How to Patch a Hole in a Plastic Trash Can: 手順 5、 2の画像 2
    • Once the mixture has fully cured, use a strip of 80 grit sandpaper to sand the hardened mixture.
    • In addition to wearing a mask, this step should be done outdoors or in a properly ventilated area to reduce the risk of inhaling the sanded debris.
  6. How to Patch a Hole in a Plastic Trash Can: 手順 6、 2の画像 1 How to Patch a Hole in a Plastic Trash Can: 手順 6、 2の画像 2
    • When you're satisfied with your sanding job, remove the duct tape from inside the trash can.
終わりに
Now you're done!
作成者
1人の作成者と共同作成されました。
Suzy Lee
メンバー登録日: 02/21/24
183 ポイント
1ガイドが承認済み
チーム
CSU Sacramento, Team G-9, Laflen Spring 2024 CSU Sacramento, Team G-9, Laflen Spring 2024人のメンバー
CSUSAC-LAFLEN-S24SGG9
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 14
過去 30 日: 42
今までの合計 110
