メインコンテンツにスキップ
How to Patch a Hole in Damaged Carpet
必要な工具と部品
  1. How to Patch a Hole in Damaged Carpet, Hole in Carpet: 手順 1、 3の画像 1 How to Patch a Hole in Damaged Carpet, Hole in Carpet: 手順 1、 3の画像 2 How to Patch a Hole in Damaged Carpet, Hole in Carpet: 手順 1、 3の画像 3
    • Place a can over the hole.
    • The can should completely cover the hole.
  2. How to Patch a Hole in Damaged Carpet: 手順 2、 3の画像 1 How to Patch a Hole in Damaged Carpet: 手順 2、 3の画像 2 How to Patch a Hole in Damaged Carpet: 手順 2、 3の画像 3
    • Press down firmly on the can.
    • Cut around the can with a utility knife.
    • Utility knives are sharp, so handle with care.
    • Only cut through the carpet. Do not cut through the carpet pad underneath.
  3. How to Patch a Hole in Damaged Carpet: 手順 3、 3の画像 1 How to Patch a Hole in Damaged Carpet: 手順 3、 3の画像 2 How to Patch a Hole in Damaged Carpet: 手順 3、 3の画像 3
    • Remove the can.
    • Lift out the old carpet.
  4. How to Patch a Hole in Damaged Carpet: 手順 4、 3の画像 1 How to Patch a Hole in Damaged Carpet: 手順 4、 3の画像 2 How to Patch a Hole in Damaged Carpet: 手順 4、 3の画像 3
    • Flip sample carpet onto its back and place down on a stable surface.
    • Place the can onto the sample carpet.
    • Trace the shape of the can with a marker.
  5. How to Patch a Hole in Damaged Carpet: 手順 5、 3の画像 1 How to Patch a Hole in Damaged Carpet: 手順 5、 3の画像 2 How to Patch a Hole in Damaged Carpet: 手順 5、 3の画像 3
    • Remove the can from the sample carpet.
    • Cut out the shape from the sample carpet using scissors.
    • Kitchen scissors are sharp. Always cut away from yourself.
  6. How to Patch a Hole in Damaged Carpet: 手順 6、 3の画像 1 How to Patch a Hole in Damaged Carpet: 手順 6、 3の画像 2 How to Patch a Hole in Damaged Carpet: 手順 6、 3の画像 3
    • Check to make sure the replacement piece of carpet fits into the hole.
    • If necessary, trim sample to fit or cut another piece.
  7. How to Patch a Hole in Damaged Carpet: 手順 7、 2の画像 1 How to Patch a Hole in Damaged Carpet: 手順 7、 2の画像 2
    • Evenly spread glue on the underside of the replacement carpet.
    • The carpet should be placed down before the glue dries.
  8. How to Patch a Hole in Damaged Carpet: 手順 8、 2の画像 1 How to Patch a Hole in Damaged Carpet: 手順 8、 2の画像 2
    • Place the glue side of the carpet down into the hole.
    • Press down firmly on the carpet with your hand.
    • Let glue dry before using the carpet.
  9. How to Patch a Hole in Damaged Carpet: 手順 9、 2の画像 1 How to Patch a Hole in Damaged Carpet: 手順 9、 2の画像 2
    • Trim carpet fibers to blend the replacement carpet with the original.
終わりに
Once the glue has dried the carpet can be walked on or vacuumed. By cutting the longer carpet fibers the replacement patch should seamlessly blend in with the original carpet.
5 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Kaleigh Smith
メンバー登録日: 01/16/20
304 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S1-G5, Raign Spring 2020 University of North Texas, Team S1-G5, Raign Spring 2020人のメンバー
UNT-RAIGN-S20S1G5
2 メンバー
5のガイドは作成済み
2件のガイドコメント
Very good. I suppose if you don't have same carpet you can match as close as possible with a new piece.
Brian Taylor - 返信
Excellent tip - thank you for sharing!!
Rama Narsing - 返信
コメントを追加
統計データ:
過去 24時間: 15
過去 7 日: 96
過去 30 日: 350
今までの合計 23,261
