はじめに
If your carpet has an unseemly stain, hole, or burn, use this guide to replace the section without the unnecessary fuss and expense of replacing the entire carpet.
Before beginning the fix, make sure the carpet and the sample piece are clean. Some homes have extra matching carpet leftover; however, carpet can always be purchased at a home improvement store.
必要な工具と部品
Once the glue has dried the carpet can be walked on or vacuumed. By cutting the longer carpet fibers the replacement patch should seamlessly blend in with the original carpet.
4 の人々がこのガイドを完成させました。
2 件のコメント
Very good. I suppose if you don't have same carpet you can match as close as possible with a new piece.
Excellent tip - thank you for sharing!!
