メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to Operate the Timer Relay Box
必要な工具と部品
  1. How to Operate the Timer Relay Box, Power the box: 手順 1、 2の画像 1 How to Operate the Timer Relay Box, Power the box: 手順 1、 2の画像 2
    • Connect the box to the mains power using an IEC C13 cable (kettle cable)
    • Check the switch is turned on.
    • Wait a few seconds, the LED under the knob will hold green to indicate the system is operating.
  2. How to Operate the Timer Relay Box, Connect the button trigger: 手順 2、 1の画像 1
    • Connect the button cable to the timer box, as shown.
  3. How to Operate the Timer Relay Box, Connect the equipment: 手順 3、 1の画像 1
    • Connect the equipment you would like the box to switch on and off.
  4. How to Operate the Timer Relay Box, Set the box to calibration mode: 手順 4、 1の画像 1
    • Turn the system off and on using the switch at the power input
    • Push and hold the rotary knob, while the system is being powered on. Release the knob when the LED is solid purple.
    • The LED will begin to flash blue when ready.
  5. How to Operate the Timer Relay Box, Set the trigger delay: 手順 5、 1の画像 1
    • Turn the knob clockwise to increase the delay, and counter clockwise to decrease. The delay changes in 0.5 second increments.
    • Turn the knob until the desired delay is achieved.
    • Press the knob to set the delay. The LED will flash green when the delay has been saved.
  6. How to Operate the Timer Relay Box, Set the power delay: 手順 6、 1の画像 1
  7. How to Operate the Timer Relay Box, Operate the Timer Box: 手順 7、 3の画像 1 How to Operate the Timer Relay Box, Operate the Timer Box: 手順 7、 3の画像 2 How to Operate the Timer Relay Box, Operate the Timer Box: 手順 7、 3の画像 3
    • Once calibrated, the timer box will switch to operation mode.
    • The LED will hold green when the box is waiting to be triggered.
    • The Box can be triggered through the button wires, or the encoder button
    • Once triggered, the LED will turn amber for the initial delay
    • The LED will turn RED when the equipment is being powered.
    • The LED will return to green once the system is ready to be triggered again.
    • Cycle the power, and trigger the system to ensure the calibration has been saved.
終わりに
作成者
1人の作成者と共同作成されました。
James Schreiber
メンバー登録日: 02/10/22
230 ポイント
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 7
過去 30 日: 29
今までの合計 387
