メインコンテンツにスキップ
How to Open Your Logitech C920s Webcam
必要な工具と部品
  1. How to Open Your Logitech C920s Webcam, Prepare your webcam for disassembly: 手順 1、 3の画像 1 How to Open Your Logitech C920s Webcam, Prepare your webcam for disassembly: 手順 1、 3の画像 2 How to Open Your Logitech C920s Webcam, Prepare your webcam for disassembly: 手順 1、 3の画像 3
    • Before you begin, unplug your webcam, close the mounting clip, and remove the privacy shutter.
  2. How to Open Your Logitech C920s Webcam, Remove the screw covers: 手順 2、 3の画像 1 How to Open Your Logitech C920s Webcam, Remove the screw covers: 手順 2、 3の画像 2 How to Open Your Logitech C920s Webcam, Remove the screw covers: 手順 2、 3の画像 3
    • Be careful not to damage the rubber pads or plastic case during this step. Work slowly and don't push hard against the webcam.
    • Push an arm of a pair of angled tweezers under one of the rubber pads on the underside of the webcam.
    • There's a small hole near the center of the back edge (farthest from the lens). Try inserting your tweezers here to prevent damaging the pad.
    • Slide the tweezers farther under the pad and lift to remove it.
  3. How to Open Your Logitech C920s Webcam: 手順 3、 1の画像 1
    • Repeat the previous step to remove the other pad.
  4. How to Open Your Logitech C920s Webcam, Remove the grille screws: 手順 4、 3の画像 1 How to Open Your Logitech C920s Webcam, Remove the grille screws: 手順 4、 3の画像 2 How to Open Your Logitech C920s Webcam, Remove the grille screws: 手順 4、 3の画像 3
    • Use a Phillips screwdriver to remove the four 4.5 mm‑long screws securing the microphone grilles.
  5. How to Open Your Logitech C920s Webcam, Remove the microphone grilles: 手順 5、 3の画像 1 How to Open Your Logitech C920s Webcam, Remove the microphone grilles: 手順 5、 3の画像 2 How to Open Your Logitech C920s Webcam, Remove the microphone grilles: 手順 5、 3の画像 3
    • Insert an opening tool in the microphone grille seam on the outer edge of the webcam.
    • Slide the opening tool along the seam to release the clips.
    • If you don't feel and hear the clips release, remove the opening tool and try again.
  6. How to Open Your Logitech C920s Webcam: 手順 6、 2の画像 1 How to Open Your Logitech C920s Webcam: 手順 6、 2の画像 2
    • Use your fingers to remove the microphone grille.
  7. How to Open Your Logitech C920s Webcam: 手順 7、 3の画像 1 How to Open Your Logitech C920s Webcam: 手順 7、 3の画像 2 How to Open Your Logitech C920s Webcam: 手順 7、 3の画像 3
    • Repeat the process to remove the microphone grille on the other side.
    • During reassembly, put the grille covers in place and squeeze firmly to engage the clips.
  8. How to Open Your Logitech C920s Webcam, Remove the lens cover screws: 手順 8、 3の画像 1 How to Open Your Logitech C920s Webcam, Remove the lens cover screws: 手順 8、 3の画像 2 How to Open Your Logitech C920s Webcam, Remove the lens cover screws: 手順 8、 3の画像 3
    • Use a Phillips screwdriver to remove the eight 8.0 mm‑long screws on the outer edges securing the lens cover.
  9. How to Open Your Logitech C920s Webcam, Remove the lens cover: 手順 9、 2の画像 1 How to Open Your Logitech C920s Webcam, Remove the lens cover: 手順 9、 2の画像 2
    • Use your fingers to lift and remove the lens cover.
  10. How to Open Your Logitech C920s Webcam, Fully open the hinges: 手順 10、 2の画像 1 How to Open Your Logitech C920s Webcam, Fully open the hinges: 手順 10、 2の画像 2
    • Tilt the main body of the webcam so its hinges are fully open.
  11. How to Open Your Logitech C920s Webcam, Remove the hinge screws: 手順 11、 2の画像 1 How to Open Your Logitech C920s Webcam, Remove the hinge screws: 手順 11、 2の画像 2
    • Use a Phillips screwdriver to remove the five screws securing the hinge mechanism:
    • Four 4.8 mm‑long screws
    • One 6.0 mm‑long screw
  12. How to Open Your Logitech C920s Webcam, Remove the mounting clip: 手順 12、 3の画像 1 How to Open Your Logitech C920s Webcam, Remove the mounting clip: 手順 12、 3の画像 2 How to Open Your Logitech C920s Webcam, Remove the mounting clip: 手順 12、 3の画像 3
    • Tilt the mounting clip so the hinges lift away from the webcam.
    • Slide the hinges out of their recess and remove the mounting clip.
    • During reassembly, make sure both hinges are fully open before sliding them into place.
  13. How to Open Your Logitech C920s Webcam, Remove the rubber spacers: 手順 13、 3の画像 1 How to Open Your Logitech C920s Webcam, Remove the rubber spacers: 手順 13、 3の画像 2 How to Open Your Logitech C920s Webcam, Remove the rubber spacers: 手順 13、 3の画像 3
    • Use tweezers or your fingers to remove the two circular rubber spacers from the outer edges of the webcam.
  14. How to Open Your Logitech C920s Webcam, Remove the inner housing: 手順 14、 3の画像 1 How to Open Your Logitech C920s Webcam, Remove the inner housing: 手順 14、 3の画像 2 How to Open Your Logitech C920s Webcam, Remove the inner housing: 手順 14、 3の画像 3
    • Use an opening tool to gently pry up and unclip the left, right, and bottom edges of the plastic inner housing.
    • During reassembly, slide the housing into place and press gently around the perimeter to engage the clips.
  15. How to Open Your Logitech C920s Webcam: 手順 15、 2の画像 1 How to Open Your Logitech C920s Webcam: 手順 15、 2の画像 2
    • Remove the inner housing.
  16. How to Open Your Logitech C920s Webcam, Your webcam is open: 手順 16、 1の画像 1
    • Your webcam is now open, with the internals accessible.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for troubleshooting help.
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
作成者
1人の作成者と共同作成されました。
Spencer Day
メンバー登録日: 09/14/22
149,272 ポイント
995のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 26
今までの合計 43
