メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to Make Coffee at iFixit Onion Bottom
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
  1. How to Make Coffee at iFixit Onion Bottom, Find the airpot: 手順 1、 1の画像 1
    • The stainless steel coffee pot with a pump is called an "airpot."
    • Locate the airpot.
    • It's usually on the counter between the water taps. If not, check the top of the drying rack in the kitchen.
    FixBotに聞いてみる
    • If the lever on top of the airpot is raised, gently push the lever release back to lower the pump lever.
    FixBotに聞いてみる
    • Pinch the buttons on either side of the spout to release the lid.
    • Lift the stem out of the airpot to remove it.
    • Pour out any leftover coffee, rinse the inside of the airpot with hot water, and let it drain over the sink for a few seconds.
    FixBotに聞いてみる
    • Remove the brew basket from the coffee maker. If there are old grounds, dump them in the compost bin and rinse the brew basket.
    FixBotに聞いてみる
  2. How to Make Coffee at iFixit Onion Bottom, Add coffee: 手順 5、 3の画像 1 How to Make Coffee at iFixit Onion Bottom, Add coffee: 手順 5、 3の画像 2 How to Make Coffee at iFixit Onion Bottom, Add coffee: 手順 5、 3の画像 3
    • Remove one large 12-cup filter from the drawer under the coffee maker and place it in the brew basket.
    • Use the 1/4-cup measuring cup to add the correct amount of coffee to the brew basket. This measuring cup is also in the draw under the coffee maker.
    • Coffee should be on the counter by the coffee maker or under the microwave beside the coffee maker.
    • For a full 2.5 L pot, about 1 cup (4 scoops) works well. Adjust to taste or use less for the smaller size.
    • But this is coffee. Follow your heart <3
    FixBotに聞いてみる
    • Slide the brew basket into place above the airpot.
    • Place the airpot (with the stem removed and the lid open) under the brew basket.
    • Set the brew size switch to 2.5 L. (Unless you want to make less coffee, then set it to 2.2 L.)
    • Set the power switch to ON. It should light up.
    • Press the PUSH TO BREW button. The "Filling" light should illuminate and you should hear water filling the tank.
    FixBotに聞いてみる
    • When brewing finishes, turn the coffee maker off.
    • Shake the brew basket to knock condensation off of the brew head. Let all coffee finish dripping out of the brew basket.
    • In one quick motion, slide the brew basket out of the coffee maker and hold it at a downward angle to prevent coffee from dripping on the floor.
    • Dispose of the grounds in the compost bin.
    • Rinse the brew basket and return it to the coffee maker.
    FixBotに聞いてみる
    • Remove the airpot from the coffee maker and place it behind the middle drip tray.
    • Insert the stem into the airpot, making sure the spout aligns with the spout hole in the airpot.
    • Close the lid and press it firmly to lock it.
    • Raise the lever until it locks into place.
    FixBotに聞いてみる
  3. How to Make Coffee at iFixit Onion Bottom, Write the date: 手順 9、 2の画像 1 How to Make Coffee at iFixit Onion Bottom, Write the date: 手順 9、 2の画像 2
    • Use the erasable marker in the drawer to write the date on the side of the airpot, so we know it's fresh.
    • Enjoy!
    FixBotに聞いてみる
終わりに
If you're feeling generous, post in Slack to let others know there's fresh coffee!
Spencer Pennington
メンバー登録日: 09/09/23
25,831 ポイント
127のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 28
今までの合計 151
