メインコンテンツにスキップ
How to Keurig K75 Platinum Brewing System
必要な工具と部品
  1. How to Keurig K75 Platinum Brewing System, How to Keurig K75 Platinum Brewing System: 手順 1、 2の画像 1 How to Keurig K75 Platinum Brewing System, How to Keurig K75 Platinum Brewing System: 手順 1、 2の画像 2
    • Before beginning the repair, turn off and unplug the brewer from any power source.
    • Move the brewer so that the bottom is easily accessible.
    • Unscrew the five 4mm silver diagrammed screws using a #2 Philips Head screwdriver.
  2. How to Keurig K75 Platinum Brewing System: 手順 2、 2の画像 1 How to Keurig K75 Platinum Brewing System: 手順 2、 2の画像 2
    • Using a spudger, gently pry open the base metal plate from the brewer.
    • Gently place the base of the brewer down.
  3. How to Keurig K75 Platinum Brewing System: 手順 3、 1の画像 1
    • Locate the vacuum apparatus within the Keurig B70 Platinum.
    • Using a #00 Phillips screwdriver, unscrew the three 15 mm black screws diagrammed.
  4. How to Keurig K75 Platinum Brewing System: 手順 4、 1の画像 1
    • Using a spudger, lift the white piece of the vacuum away from the black membrane.
    • Realign the circular pieces of the membrane so that the circles lie flush inside the black membrane apparatus.
終わりに
14 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Kristen Temnyk
メンバー登録日: 01/24/13
515 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 20-2, Maness Winter 2013 Cal Poly, Team 20-2, Maness Winter 2013人のメンバー
CPSU-MANESS-W13S20G2
4 メンバー
6のガイドは作成済み
22 件のコメント
Thank you for this, it saved me from having to purchase a new Keurig. My Keurig was not pushing water out for a cup of coffee. I tried the paperclip in the needle, which didn't work. Thanks again!!!!!
gleasonme - 返信
I cant get the little screws off of the vacuum. I broke 3 screwdrivers. Could they be glued?
Christina Garrity - 返信
After you take the white piece of the vaccuum pump off, you will see the black rubber diaphragm just below. DO NOT REMOVE the black rubber diaphragm. It is not necessary to remove this piece, and it will NOT BE POSSIBLE to re-assemble the pump after you remove it. Just clear any obstructions and put the white piece with the tube back on.
I removed the black diaphragm before I realized what it was, and now my Keurig K75 Platinum ($) is heading to the landfill. Hopefully this will prevent somebody else from making that same mistake.
John - 返信
Dang... didn't expect it to work... but it did!!
kimmpowers2004 - 返信
This worked for me. When i took off the white piece 2 of the 3 little rubbery, indented pieces were recessed and one was popped out a bit. I pushed them all in and it seemingly fixed the problem. I ran it about three times so far and it is working properly so hopefully it stays working for a while.
rsivisoulivi - 返信
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 13
過去 30 日: 39
今までの合計 34,603
