メインコンテンツにスキップ
How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom
必要な工具と部品
  1. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Open the Battery Compartment: 手順 1、 3の画像 1 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Open the Battery Compartment: 手順 1、 3の画像 2 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Open the Battery Compartment: 手順 1、 3の画像 3
    • Press down on battery door release tab to flip the battery door open.
  2. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Remove the Battery: 手順 2、 3の画像 1 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Remove the Battery: 手順 2、 3の画像 2 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Remove the Battery: 手順 2、 3の画像 3
    • Pull out the battery pack.
    • Avoid pulling on the battery wires, excess stress may break the wires, damage the power connectors, or crack the internal solder joints.
  3. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Disconnect the Battery: 手順 3、 2の画像 1 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Disconnect the Battery: 手順 3、 2の画像 2
    • Pull the two halves of the XT60 power connector apart.
    • It's a tight fit, so be careful not to hit your drone or yank on the cables when it releases!
  4. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Identifying Silver and Black Collets: 手順 4、 2の画像 1 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Identifying Silver and Black Collets: 手順 4、 2の画像 2
    • Silver-topped propeller collets unscrew counter-clockwise
    • Black-topped propeller collets unscrew clockwise
  5. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Unscrewing Silver Collets: 手順 5、 3の画像 1 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Unscrewing Silver Collets: 手順 5、 3の画像 2 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Unscrewing Silver Collets: 手順 5、 3の画像 3
    • For propellors with silver collets: Use a 12 mm wrench or socket to loosen silver collets in the counter-clockwise direction.
    • Once free, unscrew and remove the collet.
  6. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Unscrewing Black Collets: 手順 6、 3の画像 1 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Unscrewing Black Collets: 手順 6、 3の画像 2 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Unscrewing Black Collets: 手順 6、 3の画像 3
    • For propellors with black collets: Use a 12 mm wrench or socket to loosen black collets in the clockwise direction.
  7. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Remove the Propeller: 手順 7、 3の画像 1 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Remove the Propeller: 手順 7、 3の画像 2 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Remove the Propeller: 手順 7、 3の画像 3
    • Gently press down the motor shaft and lift the propeller up to remove it.
  8. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Remove Case Screws: 手順 8、 3の画像 1 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Remove Case Screws: 手順 8、 3の画像 2 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Remove Case Screws: 手順 8、 3の画像 3
    • After removing all four propellors, flip the drone over.
    • Remove the following screws from the underside of the drone:
    • Twelve 2.0 mm hex screws
    • Four Phillips #0 screws
  9. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Unplug Magnetometer: 手順 9、 3の画像 1 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Unplug Magnetometer: 手順 9、 3の画像 2 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Unplug Magnetometer: 手順 9、 3の画像 3
    • Loosen the cable from the plastic landing gear.
    • Unplug the magnetometer molex connector.
  10. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Remove the Top Shell: 手順 10、 3の画像 1 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Remove the Top Shell: 手順 10、 3の画像 2 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Remove the Top Shell: 手順 10、 3の画像 3
    • Lift up on the top portion of the shell and set it on its side.
    • Do not attempt to fully remove the case. The GPS and Magnetometer cables connect the top shell to the rest of the Phantom, be careful not to stress or break these cables.
  11. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Disconnect GPS Cable: 手順 11、 2の画像 1 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Disconnect GPS Cable: 手順 11、 2の画像 2
    • Lift the GPS cable molex connector up out of its socket on the main board.
  12. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Loosen Magnetometer Cable: 手順 12、 3の画像 1 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Loosen Magnetometer Cable: 手順 12、 3の画像 2 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Loosen Magnetometer Cable: 手順 12、 3の画像 3
    • Gently pull the slack of the magnetometer cable through the case bottom shell.
    • The case top shell should now have enough slack to work on the interior of the Phantom.
  13. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Prepare G8 Connector Cable: 手順 13、 3の画像 1 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Prepare G8 Connector Cable: 手順 13、 3の画像 2 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Prepare G8 Connector Cable: 手順 13、 3の画像 3
    • Twist the molex and cable as shown to prepare it for insertion through the case bottom shell.
  14. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Pass the G8 connector through the case: 手順 14、 3の画像 1 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Pass the G8 connector through the case: 手順 14、 3の画像 2 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Pass the G8 connector through the case: 手順 14、 3の画像 3
    • Insert the molex connector through one of the landing gear holes and case bottom shell.
    • Pull the cable through.
    • This is a really tight fit, take your time and avoid damaging the molex connector or cable. We found that gently rocking the molex connector back and forth through the hole eventually wiggled it through.
  15. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Install the mounting bracket: 手順 15、 3の画像 1 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Install the mounting bracket: 手順 15、 3の画像 2 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Install the mounting bracket: 手順 15、 3の画像 3
    • Place the H3-2D mounting bracket on the bottom side of the Phantom.
    • Line up the mounting holes and screw in the two bolts to secure the mounting bracket.
  16. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Prepare the other side of the G8 cable: 手順 16、 2の画像 1 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Prepare the other side of the G8 cable: 手順 16、 2の画像 2
    • Twist the other end of the G8 cable molex connector as shown in order to plug in the H3-2D gimbal.
  17. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Plugging in the H3-2D gimbal: 手順 17、 3の画像 1 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Plugging in the H3-2D gimbal: 手順 17、 3の画像 2 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Plugging in the H3-2D gimbal: 手順 17、 3の画像 3
    • Pass the G8 molex connector through the side of the H3-2D gimbal.
    • Plug in and firmly secure the connector.
  18. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Plug in the G8 connector: 手順 18、 3の画像 1 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Plug in the G8 connector: 手順 18、 3の画像 2 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Plug in the G8 connector: 手順 18、 3の画像 3
    • Pull the gimbal wire through the case bottom shell and plug in the connector to the G8 plug on the mainboard.
  19. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Prepare the Gimbal for installation: 手順 19、 2の画像 1 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Prepare the Gimbal for installation: 手順 19、 2の画像 2
    • Place the gimbal on the mount with the front facing the same side as the battery cover.
  20. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Mounting the Gimbal: 手順 20、 3の画像 1 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Mounting the Gimbal: 手順 20、 3の画像 2 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Mounting the Gimbal: 手順 20、 3の画像 3
    • Mount the four rubber dampers on the gimbal to the mounting bracket.
    • Pinch two sides of the rubber dampers and press it into the mounting bracket holes.
  21. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Ensure the dampers are installed securely: 手順 21、 2の画像 1 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Ensure the dampers are installed securely: 手順 21、 2の画像 2
    • Confirm the dampers are installed correctly by twisting them at least 180 degrees.
    • If a damper unmounts, it was not installed correctly. Repeat the previous step for any unmounted dampers.
  22. How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Clean up the gimbal cable: 手順 22、 2の画像 1 How to Install the Zenmuse H3-2D Gimbal on a DJI Phantom, Clean up the gimbal cable: 手順 22、 2の画像 2
    • Pull the excess slack in the gimbal cable up into the body of the Phantom.
    • When reinstalling the case top shell, be careful not to pinch any wires.
終わりに
作成者
3人の作成者と共同で作成されました。
David Hoyt
メンバー登録日: 04/09/10
4,053 ポイント
41のガイドは作成済み
チーム
Cal Poly, Team 25-89, Amido Spring 2010 Cal Poly, Team 25-89, Amido Spring 2010人のメンバー
CPSU-AMIDO-S10S25G89
4 メンバー
61のガイドは作成済み
コメント 1 件
Will this work with a Zenmuse H3-3D on DJI Phantom 1?
The Apple Enthusiast - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 4,530
