メインコンテンツにスキップ
How to Install a Heatsink on an M.2 SSD
必要な工具と部品
  1. How to Install a Heatsink on an M.2 SSD, Prepare the first thermal pad: 手順 1、 1の画像 1
    • The heatsink uses thermal pads to dissipate heat from either side of the blade SSD. The thermal pads may come with plastic liners on each side, so make sure all are removed before use.
    • Use a pair of tweezers to peel one side of protective film away from one of the thermal pads.
  2. How to Install a Heatsink on an M.2 SSD, Install the first thermal pad: 手順 2、 3の画像 1 How to Install a Heatsink on an M.2 SSD, Install the first thermal pad: 手順 2、 3の画像 2 How to Install a Heatsink on an M.2 SSD, Install the first thermal pad: 手順 2、 3の画像 3
    • Align the exposed side of the thermal pad with the bottom tray section of the heatsink assembly.
    • Lay the thermal pad down so it covers the tray evenly.
    • Use your finger to lightly press down on the thermal pad to adhere it to the surface.
  3. How to Install a Heatsink on an M.2 SSD, Prepare the second thermal pad: 手順 3、 1の画像 1
    • Use a pair of tweezers to peel one side of protective film away from the remaining thermal pad.
  4. How to Install a Heatsink on an M.2 SSD, Install the second thermal pad: 手順 4、 3の画像 1 How to Install a Heatsink on an M.2 SSD, Install the second thermal pad: 手順 4、 3の画像 2 How to Install a Heatsink on an M.2 SSD, Install the second thermal pad: 手順 4、 3の画像 3
    • Align the exposed side of the thermal pad with the top section of the heatsink.
    • Lay the thermal pad down so it covers the top section evenly.
  5. How to Install a Heatsink on an M.2 SSD, Remove the bottom thermal pad liner: 手順 5、 1の画像 1
    • Use a pair of tweezers to remove the plastic liner from the thermal pad in the tray.
    • The thermal pad might lift up from the tray as the liner is removed—this is normal. Use your finger to keep the pad in the tray.
  6. How to Install a Heatsink on an M.2 SSD, Lay the SSD in the tray: 手順 6、 3の画像 1 How to Install a Heatsink on an M.2 SSD, Lay the SSD in the tray: 手順 6、 3の画像 2 How to Install a Heatsink on an M.2 SSD, Lay the SSD in the tray: 手順 6、 3の画像 3
    • Lay the M.2 SSD into the tray, the side with the most chips facing up.
    • Make sure the SSD is centered in the tray. The tray shouldn't cover the contacts or the screw cutout.
  7. How to Install a Heatsink on an M.2 SSD, Remove the top thermal pad liner: 手順 7、 1の画像 1
    • Use a pair of tweezers to remove the plastic liner from the thermal pad on the heatsink's top section.
    • The thermal pad might lift up from the heatsink as the liner is removed—this is normal. Use your finger to keep the pad in place.
  8. How to Install a Heatsink on an M.2 SSD, Snap the heatsink in place: 手順 8、 3の画像 1 How to Install a Heatsink on an M.2 SSD, Snap the heatsink in place: 手順 8、 3の画像 2 How to Install a Heatsink on an M.2 SSD, Snap the heatsink in place: 手順 8、 3の画像 3
    • Align the top heatsink section over the SSD and the tray.
    • Firmly press the two halves together. You'll feel it "snap" into place.
  9. How to Install a Heatsink on an M.2 SSD, Check the alignment: 手順 9、 1の画像 1
    • For the SSD to fit in a desktop PC or a PlayStation 5, the heatsink needs to be centered on the SSD.
    • Make sure that the heatsink is close to the screw cutout but doesn't overhang it.
    • If you're having trouble installing your SSD, you may have to slightly adjust the heatsink's position.
    • Use your fingers to slide the SSD between the two halves of the heatsink assembly until fitment is just right.
終わりに
Installation didn’t go as planned? Check out our Computer Hardware Answers community or PlayStation 5 Answers community for troubleshooting help.
7 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Carsten Frauenheim
メンバー登録日: 03/10/20
104,390 ポイント
338のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
142 メンバー
16,235のガイドは作成済み
2 件のコメント
If your SSD has a big "warranty void if removed" sticker over the chips, do you have to remove it? Or can you stick the thermal pad over that sticker?
shamino - 返信
You can leave the sticker on the SSD! Just make sure to remove any adhesive liners on the thermal pad.
Carsten Frauenheim -
コメントを追加
統計データ:
過去 24時間: 95
過去 7 日: 670
過去 30 日: 2,254
今までの合計 33,237
