メインコンテンツにスキップ
How to Install a Gusset to Enlarge a Sleeve
必要な工具と部品
  1. How to Install a Gusset to Enlarge a Sleeve, Sleeve: 手順 1、 3の画像 1 How to Install a Gusset to Enlarge a Sleeve, Sleeve: 手順 1、 3の画像 2 How to Install a Gusset to Enlarge a Sleeve, Sleeve: 手順 1、 3の画像 3
    • Use tailor's chalk to mark 4 inches from the seam joining the sleeve to the bodice on the center sleeve seam.
    • Use tailor's chalk to mark 4 inches from the seam joining the sleeve to the bodice on the bodice seam.
  2. How to Install a Gusset to Enlarge a Sleeve: 手順 2、 2の画像 1 How to Install a Gusset to Enlarge a Sleeve: 手順 2、 2の画像 2
    • Use a seam ripper to remove the center sleeve and bodice seams up to the chalk marks.
    • Be sure to avoid splitting the horizontal seam joining the sleeve itself to the bodice.
    • Turn your garment inside out so the seams are facing towards you.
  3. How to Install a Gusset to Enlarge a Sleeve: 手順 3、 3の画像 1 How to Install a Gusset to Enlarge a Sleeve: 手順 3、 3の画像 2 How to Install a Gusset to Enlarge a Sleeve: 手順 3、 3の画像 3
    • Create a pattern by drawing a diamond that is 4 inches by 3 inches on a piece of paper.
    • Add an additional half inch to each side for seam allowance.
    • Cut out your pattern using scissors.
    • On a piece of similarly-colored fabric, pin your pattern using sewing pins to hold it still on the fabric.
    • Using fabric scissors, cut out a diamond-shaped piece of fabric following the pattern you created. This is your gusset.
  4. How to Install a Gusset to Enlarge a Sleeve: 手順 4、 3の画像 1 How to Install a Gusset to Enlarge a Sleeve: 手順 4、 3の画像 2 How to Install a Gusset to Enlarge a Sleeve: 手順 4、 3の画像 3
    • Line up your gusset against the hole in your garment.
    • The longer sides of the diamond should be pointing towards the cuff of the sleeve and the bodice.
    • Pin your gusset to the garment along the edges of the hole you created earlier.
    • You should pin them together with the edges of the gusset and hole overlapping by about half an inch for seam allowance.
  5. How to Install a Gusset to Enlarge a Sleeve: 手順 5、 2の画像 1 How to Install a Gusset to Enlarge a Sleeve: 手順 5、 2の画像 2
    • Using a sewing machine or needle and thread, take a quarter-inch stich on one edge of the diamond with a straight stitch.
    • Be sure to remove the pins ahead of your stitch as you move down the edge to avoid damage to your sewing machine.
    • Repeat this step for each of the remaining edges of the diamond.
    • Use sewing scissors to trim excess fabric along the edges past your stitch.
  6. How to Install a Gusset to Enlarge a Sleeve: 手順 6、 2の画像 1 How to Install a Gusset to Enlarge a Sleeve: 手順 6、 2の画像 2
    • Use a zig-zag stitch to seal the rough edges of the diamond using a sewing machine or needle and thread.
    • Turn your garment inside out again, so the seams are on the inside of the garment.
    • Inspect the gusset to make sure there are no gaps in your seam.
ゴール
作成者
1人の作成者と共同作成されました。
Joseph Meyers
メンバー登録日: 09/26/21
133 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 1-15, Martin Fall 2023 University of North Texas, Team 1-15, Martin Fall 2023人のメンバー
UNT-MARTIN-F23S1G15
1 メンバー
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 31
過去 30 日: 138
今までの合計 2,219
