メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to Install Ubuntu Linux
必要な工具と部品
    1. How to Install Ubuntu Linux, Download Ubuntu: 手順 1、 1の画像 1
      FixBotに聞いてみる
      コメントを追加
    2. How to Install Ubuntu Linux, Burn to Disk: 手順 2、 2の画像 1 How to Install Ubuntu Linux, Burn to Disk: 手順 2、 2の画像 2
      • Use disk burning software like ImgBurn to burn Ubuntu to a DVD, or you can use a USB flash drive instead. If you use a flash drive, download UNetbootin and create your installation media.
      • You do not need to burn Ubuntu to a disk if you are using a virtual machine.
      FixBotに聞いてみる
      コメントを追加
    3. How to Install Ubuntu Linux, Boot to installation media: 手順 3、 1の画像 1
      • I recommend trying Ubuntu in a virtual machine, which is what I did.
      • If you are using a real computer, you may need to configure the BIOS or press a key on system startup. If you need to change the BIOS settings, set any Optical Drives or USB CD-ROM drives as the first boot priority.
      • If you want to use a virtual machine, set CD/DVD as the first boot priority and mount the iso file to the machine. There is plenty of virtualization software out there, like VirtualBox.
      • If you have successfully booted into the installation media, you will see this picture.
      • Click on the big "Install Ubuntu" button.
      FixBotに聞いてみる
      コメントを追加
    4. How to Install Ubuntu Linux, Install Ubuntu: 手順 4、 1の画像 1
      • After a screen asking about additional software, you will asked what you would like to do with your hard disk.
      • If the installer refers to any sort of dual-booting, you must quit the installer and make unallocated space on your hard disk somehow. (See warning for info.)
      • If you are experienced with partitions, you may use this partition editor.
      • If you decide to use the partition editor, please be very careful. Partitions made with this partition editor can cause any other operating systems to become inaccessible.
      FixBotに聞いてみる
      コメントを追加
終わりに
That's it! Now you can try Ubuntu all you want.
キャンセル: このガイドを終了できませんでした。
7 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Thomas Sirack
メンバー登録日: 07/25/15
561 ポイント
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 28
今までの合計 1,568
