メインコンテンツにスキップ
How to Install A Car Camera Into Cigar Jack
  1. How to Install A Car Camera Into Cigar Jack, Set up the camera at your computer desk.: 手順 1、 1の画像 1
    • Connect up the car camera to your PC via a USB cable.
    • Browse through the settings menu and key in any required information. E.g Time & Date Stamp, Voice Recording(On/Off)
    • Insert a Class 10 SD Card and format the SD Card using the device's setting menu.
    • Try recording a video at your computer desk and test the playback function
  2. How to Install A Car Camera Into Cigar Jack, Attach the camera to your windscreen: 手順 2、 1の画像 1
    • Plunge the camera with the suction cup to your preferred point.
    • Tip: Wet the windscreen with some clean water before plunging in the suction cup for a stronger hold.
  3. How to Install A Car Camera Into Cigar Jack, Tuck the USB Cable into overhead fabric: 手順 3、 1の画像 1
    • Start tucking the USB Cable into the gap above the passenger seat.
    • Align the cable between the gap and secure the cable in place by pushing in the wires using your four fingers.
  4. How to Install A Car Camera Into Cigar Jack, Remove the side trunking slightly: 手順 4、 1の画像 1
    • The side door trunking can be easily detached by giving it a firm nudge.
    • Hide the cable beneath the trunking leaving the free end nearer to the passenger seat as depicted in the picture.
  5. How to Install A Car Camera Into Cigar Jack, Run the cable along the rubber sleeve by the side door: 手順 5、 1の画像 1
    • Push the cable into the rubber sleeve using your thumb
    • Keep your thumb in the sleeve and run the cable downwards until you reach the glove compartment area.
  6. How to Install A Car Camera Into Cigar Jack, Hook the cables onto any crevices you can find underneath the glove box: 手順 6、 1の画像 1
    • Use some duct tape to hold the cables in place if there are no crevices underneath your glove compartment.
    • Hang on there, you're almost done.
  7. How to Install A Car Camera Into Cigar Jack, Connect up the USB cable into the Cigar Jack Port: 手順 7、 1の画像 1
    • Plug in the USB convertor into the Cigar Jack Port.
    • Connect up the USB cable of the car camera into the port.
    • Start your engine if you haven't done so, car camera should switch on automatically upon detecting power from the car.
  8. How to Install A Car Camera Into Cigar Jack, You are done.: 手順 8、 1の画像 1
    • Ensure the camera is powered correctly, look for a charging indicator icon on your car camera device.
    • Make sure there is a red rounded icon that indicates "Record in Progress" before you drive off everyday.
    • You are done, enjoy the reassuring driving experience and be safe.
終わりに
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Alden
メンバー登録日: 07/01/16
308 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 33
今までの合計 3,156
