メインコンテンツにスキップ
How to Hook up Front Panel Connectors to an ATX Motherboard
必要な工具と部品
  1. How to Hook up Front Panel Connectors to an ATX Motherboard, How to Hook up Front Panel Connectors to an ATX Motherboard: 手順 1、 3の画像 1 How to Hook up Front Panel Connectors to an ATX Motherboard, How to Hook up Front Panel Connectors to an ATX Motherboard: 手順 1、 3の画像 2 How to Hook up Front Panel Connectors to an ATX Motherboard, How to Hook up Front Panel Connectors to an ATX Motherboard: 手順 1、 3の画像 3
    • Lay your PC on its side and unscrew the side panel thumb screws. (Open your PC case)
    • For some computer cases you may need a screw driver to remove actual screws.
  2. How to Hook up Front Panel Connectors to an ATX Motherboard: 手順 2、 2の画像 1 How to Hook up Front Panel Connectors to an ATX Motherboard: 手順 2、 2の画像 2
    • Once the screws are removed lift off the side panel to expose the motherboard and internal cables.
    • Locate where the front panel pins are.
  3. How to Hook up Front Panel Connectors to an ATX Motherboard: 手順 3、 3の画像 1 How to Hook up Front Panel Connectors to an ATX Motherboard: 手順 3、 3の画像 2 How to Hook up Front Panel Connectors to an ATX Motherboard: 手順 3、 3の画像 3
    • Plug the cable marked Reset SW into the motherboard. This will allow your reset button to actually work.
  4. How to Hook up Front Panel Connectors to an ATX Motherboard: 手順 4、 3の画像 1 How to Hook up Front Panel Connectors to an ATX Motherboard: 手順 4、 3の画像 2 How to Hook up Front Panel Connectors to an ATX Motherboard: 手順 4、 3の画像 3
    • Plug the Power SW cable in above the Reset SW on the motherboard. This will allow you to turn on your computer with the power button on the front of your PC case.
  5. How to Hook up Front Panel Connectors to an ATX Motherboard: 手順 5、 3の画像 1 How to Hook up Front Panel Connectors to an ATX Motherboard: 手順 5、 3の画像 2 How to Hook up Front Panel Connectors to an ATX Motherboard: 手順 5、 3の画像 3
    • Plug the Power Led + into the top left prong. Positive goes on the left prong.
  6. How to Hook up Front Panel Connectors to an ATX Motherboard: 手順 6、 3の画像 1 How to Hook up Front Panel Connectors to an ATX Motherboard: 手順 6、 3の画像 2 How to Hook up Front Panel Connectors to an ATX Motherboard: 手順 6、 3の画像 3
    • Connect the Power Led - cable to the prong on the right.
    • This is the final cable structure.
  7. How to Hook up Front Panel Connectors to an ATX Motherboard: 手順 7、 1の画像 1
    • Power LED
    • Power Switch
    • Reset Switch
終わりに
To reassemble your device, follow the instructions, steps 1 and 2, in reverse order.
8 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Nathan Carini
メンバー登録日: 03/26/21
297 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team S1-G5, O'Connell Spring 2021 UMass Dartmouth, Team S1-G5, O'Connell Spring 2021人のメンバー
UMASSD-O'CONNELL-S21S1G5
1 メンバー
6のガイドは作成済み
コメント 1 件
Petite précision :
Les broches sur lesquels il faut brancher les connecteurs des différents éléments du boitier sont indiquées dans la notice de la carte mère (button power, LEDs, etc.). L’emplacement et l’ordre de branchement des différents éléments du boitier est susceptible de varier selon le modèle de la carte mère.
Cela concerne aussi le buzzer si vous en avez un.
Brendan - 返信
コメントを追加
統計データ:
過去 24時間: 130
過去 7 日: 825
過去 30 日: 3,407
今までの合計 72,880
