メインコンテンツにスキップ
How to Hem Sweatpants
必要な工具と部品
  1. How to Hem Sweatpants, How to Hem Sweatpants: 手順 1、 2の画像 1 How to Hem Sweatpants, How to Hem Sweatpants: 手順 1、 2の画像 2
    • Use the seam ripper to remove the seams along the hem of the bottom of the pants.
  2. How to Hem Sweatpants: 手順 2、 1の画像 1
    • Remove the elastic band from the pants. Keep the elastic for later.
  3. How to Hem Sweatpants: 手順 3、 1の画像 1
    • Place pins where you want the pants to end.
  4. How to Hem Sweatpants: 手順 4、 3の画像 1 How to Hem Sweatpants: 手順 4、 3の画像 2 How to Hem Sweatpants: 手順 4、 3の画像 3
    • Measure the length of the cuff.
    • Measure how long the pants need to be cut.
    • Keeping in mind a small length below the pins for the new cuff, mark where you want to cut with your washable marker.
  5. How to Hem Sweatpants: 手順 5、 1の画像 1
    • Using the fabric scissors, cut along the line you marked, making sure to keep a straight and steady line.
  6. How to Hem Sweatpants: 手順 6、 1の画像 1
    • Fold the new end of the pants outward, at a minimum of double the length of the elastic band.
  7. How to Hem Sweatpants: 手順 7、 2の画像 1 How to Hem Sweatpants: 手順 7、 2の画像 2
    • Place the elastic band on top of the fold from the previous step.
    • Place the top of the elastic along the pin line.
    • Using the needle and thread, sew both ends of the elastic band to the seam running vertically up and down the pant leg.
  8. How to Hem Sweatpants: 手順 8、 2の画像 1 How to Hem Sweatpants: 手順 8、 2の画像 2
    • Fold the top of the folded fabric section back over the elastic, using the pins as the top line.
    • Place pins along the bottom of the new fold to keep the fabric in place.
  9. How to Hem Sweatpants: 手順 9、 3の画像 1 How to Hem Sweatpants: 手順 9、 3の画像 2 How to Hem Sweatpants: 手順 9、 3の画像 3
    • Sew a new hem along the line created by the new pins. You can either hand-sew or use a sewing machine.
    • Sew ONLY along the new pins placed in the previous step. Do not sew along the first row of pins created at the beginning.
    • Once the sewing is complete, remove all the pins and undo the first fold.
    • The last photo provides a sample of the finished product.
ゴール
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
James Harris
メンバー登録日: 02/02/21
181 ポイント
1ガイドが承認済み
1件のガイドコメント
Thanks very much for this tutorial because at 5’ I have to shorten everything. Now I can alter sweatpants that are made for 6’ tall people.
Ruthann45 - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 50
過去 30 日: 219
今までの合計 14,131
