メインコンテンツにスキップ
How to Hand Sew Patches Onto a Garment
必要な工具と部品
  1. How to Hand Sew Patches Onto a Garment, How to Hand Sew Patches Onto a Garment: 手順 1、 1の画像 1
    • Place the cardboard separator in between the layers of your chosen garment.
    • This helps to avoid stitching both sides of the garment together.
  2. How to Hand Sew Patches Onto a Garment: 手順 2、 1の画像 1
    • Choose a color of thread that matches or contrasts with the color of your patch.
  3. How to Hand Sew Patches Onto a Garment: 手順 3、 2の画像 1 How to Hand Sew Patches Onto a Garment: 手順 3、 2の画像 2
    • Choose where you’d like the patch to sit on the garment.
    • To help with stability, use pins and iron the garment to maintain the position of the patch.
  4. How to Hand Sew Patches Onto a Garment: 手順 4、 2の画像 1 How to Hand Sew Patches Onto a Garment: 手順 4、 2の画像 2
    • Push the thread through the eye of the needle.
    • To prevent fraying, twist the ends of the thread to tighten it.
  5. How to Hand Sew Patches Onto a Garment: 手順 5、 3の画像 1 How to Hand Sew Patches Onto a Garment: 手順 5、 3の画像 2 How to Hand Sew Patches Onto a Garment: 手順 5、 3の画像 3
    • Insert the needle through the backside of the shirt and patch.
    • Pull the needle until the thread is taut.
    • Insert the needle through the outside of the shirt and patch, at the length you’d like your stitch to be.
    • Pull the needle again until the thread is taut.
  6. How to Hand Sew Patches Onto a Garment: 手順 6、 3の画像 1 How to Hand Sew Patches Onto a Garment: 手順 6、 3の画像 2 How to Hand Sew Patches Onto a Garment: 手順 6、 3の画像 3
    • On the backside, insert the needle at a similar distance to the previous stitch, away from the previous stitch.
    • Insert the needle at the end of the previous stitch; this will be stitching backwards.
  7. How to Hand Sew Patches Onto a Garment: 手順 7、 3の画像 1 How to Hand Sew Patches Onto a Garment: 手順 7、 3の画像 2 How to Hand Sew Patches Onto a Garment: 手順 7、 3の画像 3
    • Lace the needle through the extra fabric of the shirt that is covered by the patch.
    • Hold both ends of your thread and rotate it around the needle twice.
    • Create a loop using the thread and pull your needle through the loop.
    • Pull until the knot has formed (no extra thread is leftover).
    • Cut the thread with 1-2 inches to spare.
  8. How to Hand Sew Patches Onto a Garment: 手順 8、 1の画像 1
    • Finished Product!
ゴール
作成者
2人の作成者と共同で作成されました。
Shannon Ikemiya
メンバー登録日: 04/24/24
157 ポイント
1ガイドが承認済み
チーム
UC Davis, Team 2-1, Whithaus Spring 2024 UC Davis, Team 2-1, Whithaus Spring 2024人のメンバー
UCD-WHITHAUS-S24S2G1
4 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 24
今までの合計 46
