メインコンテンツにスキップ
How to Glue a Broken High Heel
必要な工具と部品
  1. How to Glue a Broken High Heel, How to Glue a Broken High Heel: 手順 1、 1の画像 1
    • Locate a high heeled shoe that has its heel partly or completely removed from its base.
    • Remove loose dirt , surface soil, and debris from the heel and sole of the shoe using a dry, soft-bristled shoe brush or damp paper towel.
    • Blot the fabric with a dry paper towel and allow the shoes to air dry away from direct heat and sunlight.
  2. How to Glue a Broken High Heel: 手順 2、 1の画像 1
    • Use sandpaper to repair structural damage and roughen the material to make it easier for glue to bond. Lightly rub the heel and sole of the show in small, concentric motions until the surface is completely leveled and smooth.
    • Apply a generous coating of superglue on both the heel and the sole of the shoe so that a thick layer of glue forms between the sole and heel layers.
    • Caution: Heavy-duty super glue can cause skin irritation and may produce an allergic reaction if exposed to in high levels.
  3. How to Glue a Broken High Heel: 手順 3、 1の画像 1
    • Using your hands, use substantial pressure to press the heel and shoe together to enforce the bond for 10-15 minutes.
  4. How to Glue a Broken High Heel: 手順 4、 1の画像 1
    • Secure the heel in place with either rubber bands or a heavy object for at least 24 hours.
終わりに
作成者
2人の作成者と共同で作成されました。
Tibirni Yusuf
メンバー登録日: 09/28/22
121 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team 1-5, Cameron Fall 2022 University of Memphis, Team 1-5, Cameron Fall 2022人のメンバー
UM-CAMERON-F22S1G5
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 55
今までの合計 1,203
