メインコンテンツにスキップ
How to Force Restart an iPhone 4S
  1. How to Force Restart an iPhone 4S, How to Force Restart an iPhone 4S: 手順 1、 2の画像 1 How to Force Restart an iPhone 4S, How to Force Restart an iPhone 4S: 手順 1、 2の画像 2
    • Press and hold the Home button.
    • While holding the Home button, press and hold the Sleep/Wake button.
    Helpful.......it's working. PTL!!!! It's saved.
    Renee A Watson - 返信
    i cant use my power button because it cant function
    Elsa Cagampang - 返信
    please help me.. how can i restart my phone using emergency call beacause the power button of my cp it cannot function.
    Elsa Cagampang - 返信
    Its not workiing because the home button of my phone is malfunctioned
    Niranjan Manoj - 返信
  2. How to Force Restart an iPhone 4S: 手順 2、 2の画像 1 How to Force Restart an iPhone 4S: 手順 2、 2の画像 2
    • Continue holding both buttons for about 10 seconds, until the Apple logo appears.
    What do you do if the apple doesn’t appear?
    David Wilmot - 返信
ゴール
233 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Evan Noronha
メンバー登録日: 02/05/15
223,472 ポイント
168のガイドは作成済み
23 件のコメント
what if our power butoon is broken/
Autumn Harris - 返信
Under settings, accessability, turn on assistive touch. You'll have a grey dot floating around on your screen. When you touch the dot, it brings up the full "menu." Touch "device" then a lock button option will show. Press and hold the lock icon. You'll then have the "slide to power off" option. Turn off. Give it a couple minutes. Don't panic, even without the working power button to turn it back on, it's still doable! Just plug the phone in and it'll power right on.
Heather Powers -
It worked, I can't believe this! Thank you so much, I tried everything I could think of to get it started. I put it in a bag of rice for 12 hours, a bed warmer, blow dryer, and nothing. I started looking for repair shop's, and stumble on your site, which included all iphones. I went to my phone model and the instructions said force start, and I tried it and presto, I'm back in business. THANK YOU! 724-309-3210
Dr Ed Day - 返信
Great Instructions! Thank you.
georgiaruocco - 返信
bravo c superbe
perdereau - 返信
my iphone is not getting started. it turns on when i plug in the cable but still stucks in the iphone logo.
Tarif Hasan - 返信
Thank you Heather Powers! You must be one of the geniuses ;p
Susanne Vierbergen - 返信
Thank you so much my phone is now working it has been off, the past 4 days but its now finally working 100% :-)
Asia Kakorokoro - 返信
not helpful whatso ever dont listen to him he is a lieer
thomas andrews - 返信
soz he dosent reall suck and lie
thomas andrews - 返信
can anyone help me my iphone wont go to the main home screen i turn my phone on and its shows itunes symbol and charger how do i removve that
Dawn Henry - 返信
Thank you it brot my iphone 4S back, great
genebrn - 返信
My home button is broken.
Ruby Magdalene Acol-Acol - 返信
Please tell me what comes next. I get logo then what do I do
Billie kennedy - 返信
you just wait until your homescreen appears :3
YTKatten -
Works fine. Online instructions are well illustrated, but it would be helpful to WARN potential users that the little screws holding the battery clip are really tough to orient and re-insert. Be sure to work on a clean white surface; so, if they fall off the driver they don’t wind up on the floor. You’ll never find them there. I was lucky, they stuck to the magnetic tool that came with the kit.
Robert Vrijenhoek - 返信
IT all went smoothly for me, but my own unsteady hand was my worst enemy (I am 65+), and a constant fear that I would drop one of those nearly invisible screws on the carpet below.
Gary Liebisch - 返信
i didnt put the display in the perfect way in the phone, had to reopen it again, but put too much pressure onto it and i think i killed some cable?
its not doing anything again so..
is there anything i can do?
maximmerle - 返信
Merhaba , iPhone 4s şarja takıldığında apple logosu geliyor biraz durup sonra gidiyor böyle döngü ediyor ve telefon açılmıyor
oyun ustası 2004.2005 - 返信
Çözüm nedir acaba?
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 48
過去 30 日: 199
今までの合計 84,641
