メインコンテンツにスキップ
How to Fix the Worx Pegasus Workbench lower tray
必要な工具と部品
  1. How to Fix the Worx Pegasus Workbench lower tray, Re-assemble per factory: 手順 1、 2の画像 1 How to Fix the Worx Pegasus Workbench lower tray, Re-assemble per factory: 手順 1、 2の画像 2
    • If yours became detached, make sure you begin by manually re-assembling the tray as it came from factory.
  2. How to Fix the Worx Pegasus Workbench lower tray, Drill through the hinge: 手順 2、 2の画像 1 How to Fix the Worx Pegasus Workbench lower tray, Drill through the hinge: 手順 2、 2の画像 2
    • Drill a small hole, the smallest possible but large enough to allow a zip tie to go through. I used a 1.5mm drill bit.
  3. How to Fix the Worx Pegasus Workbench lower tray, Route a Zip Tie: 手順 3、 2の画像 1 How to Fix the Worx Pegasus Workbench lower tray, Route a Zip Tie: 手順 3、 2の画像 2
    • Route a Zip Tie through the hole you just drilled and around the hinge barrel.
    • Cut the excess with scissors or wire cutters.
    • Do this procedure at least on two hinges: the leftmost and rightmost. For best results, address all six hinges.
  4. How to Fix the Worx Pegasus Workbench lower tray, Enjoy your reliable workbench: 手順 4、 1の画像 1
    • If done correctly, the tray is not going to fail again.
    • This fix also adds a little bit more strength to the lower tray.
    • Enjoy!
ゴール
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
RodCastler
メンバー登録日: 10/29/22
373 ポイント
2のガイドは作成済み
1件のガイドコメント
Nice job. Only critique is a better or close up of where you drill the holes for the zip ties. Hard to see from your pics. I figured it out and added all 6 to my hinges as that tray falls off non-stop. Thanks! I also added 4 other zip ties to the 4 small exterior holes on the outside of the tray that lock the perimeter attachment hinges into place as well.
Ray Wright - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 43
今までの合計 507
