メインコンテンツにスキップ
How to Fix the Neckline of a T-Shirt
必要な工具と部品
  1. How to Fix the Neckline of a T-Shirt, How to Fix the Neckline of a T-Shirt: 手順 1、 1の画像 1
    • Turn the shirt inside out and cut a long strip of thread.
    • Use a bit more thread than you think is necessary since you can always cut any excess thread. I used about three feet of thread, but it depends on the shirt!
  2. How to Fix the Neckline of a T-Shirt: 手順 2、 2の画像 1 How to Fix the Neckline of a T-Shirt: 手順 2、 2の画像 2
    • Once you cut your string, thread it through the sewing needle. Bring both of the ends together and get ready to use both strands to tie a knot.
  3. How to Fix the Neckline of a T-Shirt: 手順 3、 2の画像 1 How to Fix the Neckline of a T-Shirt: 手順 3、 2の画像 2
    • Flip your shirt inside-out and start threading your needle in and out of the top of the neckline.
    • As shown in the second picture, avoid poking the needle all the way through to the other side! There's a thin pocket inside of the neckline, so be sure to weave the needle and thread through one side only.
  4. How to Fix the Neckline of a T-Shirt: 手順 4、 1の画像 1
    • As you thread your needle throughout the neckline, be sure to pull the thread completely through each hole that you make. Repeat this process around the neckline until you reach your starting point.
    • To tighten the neckline, hold down on the shirt itself as you go along and pull on the needle-end of the thread. This will cause the fabric of the shirt to bunch up.
    • You want the fabric to bunch up only slightly, otherwise it'll be too tight for you to stick your head through. Try to find a good balance!
  5. How to Fix the Neckline of a T-Shirt: 手順 5、 2の画像 1 How to Fix the Neckline of a T-Shirt: 手順 5、 2の画像 2
    • After going around once, tie together the ends that you started and finished with. Tying only one knot leaves a good amount of room for it to snap, so tie two additional knots for a total of three overhand knots to strengthen it.
  6. How to Fix the Neckline of a T-Shirt: 手順 6、 1の画像 1
    • Cut off any excess thread that you're left with after tying the threads together. Leave about a quarter of an inch of excess thread and be sure not to cut the knot itself.
  7. How to Fix the Neckline of a T-Shirt: 手順 7、 1の画像 1
    • Start running your thread through the top, exactly as you did with the bottom.
  8. How to Fix the Neckline of a T-Shirt: 手順 8、 2の画像 1 How to Fix the Neckline of a T-Shirt: 手順 8、 2の画像 2
    • Try to keep the spacing between each hole that you thread as similar to the bottom, and remember only to move the needle through one side.
    • Once you complete the top, bring the beginning and end of the threads together and tie three overhand knots as you did before. Then, cut the extra thread once more, leaving about a quarter of an inch of said thread.
  9. How to Fix the Neckline of a T-Shirt: 手順 9、 1の画像 1
    • After completing the top, you're finished! Your neckline should be noticeably tighter. Once you slip your head through the hole, it's going to feel and quite possibly look like a whole new shirt.
    • If the thread feels too tight, you may want to consider cutting the thread and threading it again, since attempting to jam your head through like I did may cause the threads to break.
終わりに
Give yourself a pat on the back. You’ve breathed new life into an aged shirt!
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Noah Aguilar
メンバー登録日: 10/28/20
223 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team S12-G15, Harris Fall 2020 CSU Los Angeles, Team S12-G15, Harris Fall 2020人のメンバー
CSULA-HARRIS-F20S12G15
1 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 30
過去 30 日: 99
今までの合計 32,163
