はじめに
We all have that favorite shirt that we can’t bear to live without. If you don’t have the funds to buy a new shirt, don’t want to spend the money, or just want to try your hand at an easier sewing project, this is the guide for you. If your shirt feels too loose, you may qualify for a neckline repair.
Shirts can become worn over time due to the extended use of hangers or as a result of being stretched. The threads that were once used to hold them together can even become inelastic and snap. It’s completely common! Without requiring much sewing experience, this guide will show you a neat hand-sewing fix for the neckline of a loose T-Shirt. By using just two lengthy elastic threads, any old shirt can be reborn!
Before you begin, it’s important to note that sewing by hand (especially for the first time) increases the chances of making the neckline of the shirt too tight. Step 4 covers a good practice to consider when fixing the neckline to avoid making it too tight.
必要な工具と部品
Turn the shirt inside out and cut a long strip of thread.
As you thread your needle throughout the neckline, be sure to pull the thread completely through each hole that you make. Repeat this process around the neckline until you reach your starting point.
To tighten the neckline, hold down on the shirt itself as you go along and pull on the needle-end of the thread. This will cause the fabric of the shirt to bunch up.
Try to keep the spacing between each hole that you thread as similar to the bottom, and remember only to move the needle through one side.
Once you complete the top, bring the beginning and end of the threads together and tie three overhand knots as you did before. Then, cut the extra thread once more, leaving about a quarter of an inch of said thread.
Give yourself a pat on the back. You’ve breathed new life into an aged shirt!
3 の人々がこのガイドを完成させました。
