メインコンテンツにスキップ
How to Fix the James Donkey RS2 2.0 Switch or Motherboard
必要な工具と部品
  1. How to Fix the James Donkey RS2 2.0 Switch or Motherboard, Switch or Motherboard: 手順 1、 2の画像 1 How to Fix the James Donkey RS2 2.0 Switch or Motherboard, Switch or Motherboard: 手順 1、 2の画像 2
    • The first step is to disassemble all the pieces to make sure all the parts are separated.
  2. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 2、 2の画像 1 How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 2、 2の画像 2
    • Make sure all the cable is unplugged to prevent an accident from happening.
  3. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 3、 3の画像 1 How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 3、 3の画像 2 How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 3、 3の画像 3
    • Unplug all the cables before removing any other parts of the keyboard.
  4. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 4、 3の画像 1 How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 4、 3の画像 2 How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 4、 3の画像 3
    • Unscrew the small board (including 2 m 2 4 mm screws) to make it easier to figure out where the trouble is.
  5. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 5、 2の画像 1 How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 5、 2の画像 2
    • Then plug it back into the PCB. What we get will be a small board connected to the big board.
  6. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 6、 1の画像 1
    • Connect the board to the computer, and turn the circuit on to test to see where the problem is.
  7. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 7、 1の画像 1
    • To figure out if is it connected or not, first open the key tester on a computer that has been connected to the keyboard.
  8. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 8、 1の画像 1
    • Use the metal tweezer to connect the silver part under the PCB.
  9. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 9、 1の画像 1
    • If everything works fine, it should light in green, which means the key has been sensed.
  10. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 10、 1の画像 1
    • If there is just one single key that is unable to react, then switch it.
  11. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 11、 1の画像 1
    • If there is a line that has no reaction, which means PCB is malfunctioning, send it back for repair.
  12. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 12、 2の画像 1 How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 12、 2の画像 2
    • Here is how to switch the switches. First, unplug the keycap.
  13. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 13、 2の画像 1 How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 13、 2の画像 2
    • Then unplug the switch.
  14. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 14、 3の画像 1 How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 14、 3の画像 2 How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 14、 3の画像 3
    • After that, plug in a new switch.
  15. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 15、 2の画像 1 How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 15、 2の画像 2
    • Finally, put back the keycap.
  16. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 16、 2の画像 1 How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 16、 2の画像 2
    • Congratulations! You are done with the replacement. Now put the board back, screw it with 2 4 mm M2 screws, and connect all the cables.
  17. How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 17、 3の画像 1 How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 17、 3の画像 2 How to Fix the James Donkey RS2 2.0 Switch or Motherboard: 手順 17、 3の画像 3
    • When everything is done, put back the top layer.
終わりに
作成者
4人の作成者と共同で作成されました。
Yichen Gu
メンバー登録日: 10/29/23
265 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 5-10, Kershman Fall 2023 CSU Los Angeles, Team 5-10, Kershman Fall 2023人のメンバー
CSULA-KERSHMAN-F23S5G10
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 35
今までの合計 198
