メインコンテンツにスキップ
How to Fix iPhone X Face ID Not Working After Screen Replacement
ビデオの概要
  1. How to Fix iPhone X Face ID Not Working After Screen Replacement, Malfunction: 手順 1、 1の画像 1
    • The iPhone X shows an alert that says it is ‘unable to activate Face ID on this iPhone’.
    • When trying to setup Face ID on the iPhone X, we get the message 'Face ID is Not Available, try setting up Face ID later'.
    • Also, according to the feedback from our client, Face ID on the phone is available after being dropped. However, Face ID is not available after replacing of the display assembly.
    • Unavailable Face ID might be caused by improper operation when replacing the display assembly.
  2. How to Fix iPhone X Face ID Not Working After Screen Replacement, Diagnose: 手順 2、 1の画像 1
    • Check the Infrared camera and dot projector module under Microscope. Nothing goes wrong.
    • Let’s move to the Flood illuminator module on the earpiece speaker and front sensor assembly.
    • We can see clearly that flex cable next to the Flood illuminator module is damaged.
  3. How to Fix iPhone X Face ID Not Working After Screen Replacement, Troubleshoot: 手順 3、 1の画像 1
    • Now, we need to separate the earpiece speaker from the assembly.
    • Remove the ambient light sensor module flex cable afterwards.
  4. How to Fix iPhone X Face ID Not Working After Screen Replacement, Troubleshoot: 手順 4、 1の画像 1
    • Turn the flex cable upside-down and secure it again. Remove the Flood illuminator module.
    • Prepare a new flex cable. Apply some Paste Flux to the bonding pad and solder the detached Flood illuminator module.
  5. How to Fix iPhone X Face ID Not Working After Screen Replacement, Troubleshoot: 手順 5、 1の画像 1
    • Solder the detached ambient light sensor module flex cable.
    • Now we need to solder the earpiece speaker back to flex cable and get it installed to the display assembly. Secure with screws afterwards.
  6. How to Fix iPhone X Face ID Not Working After Screen Replacement, Test: 手順 6、 1の画像 1
    • Go to Settings > Face ID & Passcode > Reset Face ID. Face ID can be setup successfully
終わりに
To fully understand Face ID, you can also check Face ID Teardown here.
22 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Phryne
メンバー登録日: 11/17/19
20,329 ポイント
18のガイドは作成済み
7 件のコメント
Why not just buy a new cable? They’re $10-$15 on eBay. Soldering seems like it’s take way more time and possibly even cost more money than just buying a new cable.
brian - 返信
Face ID will no longer function if the original flex connectors are damaged or replace with new ones. Even if the flex connectors are properly soldered just as they were originall it will still fail. There is some marker in the cables which the module is checking for and if the cables are changed then the marker (most likely the serial number of the flex) will mismatch and fail to work. The same was true with Touch ID as well
James Sassu -
What brian said is correct, if the cable is changed it will not match.This full video looks more detailed(21) Troubleshooting iPhone X Problems of Floodlight Sensor, True Tone, and Face Recognition - YouTube
Kasis Cheng - 返信
%#*!^@ I hope I didnt damage the face id cable during my battery change 😩 I sealed it up as well so it'll be a pain to open it up again to double check
pokoro - 返信
Why my Face ID is not work what I we use to do it again
Lawrence - 返信
コメントを追加
統計データ:
過去 24時間: 107
過去 7 日: 1,001
過去 30 日: 5,144
今までの合計 312,413
