メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to Fix an Unstable Ikea Poang Chair
必要な工具と部品
  1. How to Fix an Unstable Ikea Poang Chair, How to Fix an Unstable Ikea Poang Chair: 手順 1、 1の画像 1
    • Start by removing the seat cushion from the frame.
  2. How to Fix an Unstable Ikea Poang Chair: 手順 2、 3の画像 1 How to Fix an Unstable Ikea Poang Chair: 手順 2、 3の画像 2 How to Fix an Unstable Ikea Poang Chair: 手順 2、 3の画像 3
    • Remove the upper bolt, which attaches the back of the seat to the armrests.
    • Remove the lower bolt, which is the upper bolt attaching the seat to the legs.
    • Remove the same bolts on the opposite side of the chair.
    • To loosen the bolts, turn the Allen wrench to the LEFT, as shown in the video.
  3. How to Fix an Unstable Ikea Poang Chair: 手順 4、 1の画像 1
    • Separate the back and seat of the chair from the legs and the armrest.
  4. How to Fix an Unstable Ikea Poang Chair: 手順 5、 2の画像 1 How to Fix an Unstable Ikea Poang Chair: 手順 5、 2の画像 2
    • Re-attach the bolts removed in Steps 2 and 3. Put each bolt into the correct location before tightening each bolt.
    • If the bolt attaching the seat tightens too easily, it is not in the hole and rests above or below the wood of the seat. This is what causes the tipping or dipping of the seat.
    • When attaching the bolt for the back of the chair, insert a plastic washer between the wood of the chair leg and the wood of the chair back. Without this washer, the two pieces will not sit flush. This allows the chair to shift and may cause the chair to become unstable.
    • For maximum stability, fully tighten all of the bolts in the chair.
    • As shown in the video, tighten by turning the Allen wrench to the RIGHT.
  5. How to Fix an Unstable Ikea Poang Chair: 手順 7、 1の画像 1
    • Set the chair cushion on the chair seat.
    • Secure the Velcro on the cushion to the Velcro on the chair back.
ゴール
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Erik Romanski
メンバー登録日: 03/30/16
191 ポイント
1ガイドが承認済み
チーム
Michigan Tech, Team 1-21, Lauer Spring 2016 Michigan Tech, Team 1-21, Lauer Spring 2016人のメンバー
MTU-LAUER-S16S1G21
1 メンバー
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 32
過去 30 日: 131
今までの合計 17,414
