はじめに
If you notice that the print bed on your Creality Ender-3 Pro 3D printer is wobbling, the wheel bearings under the print bed that align with the y-axis have probably come loose from the railing holding them in place.
The printer uses very thin layers of filament, so any sort of movement outside of the precise instructions given to it will result in failed prints until a fix is made. This guide will illustrate how to turn the eccentric nut connected to the loose wheel bearing in order to secure the wheel bearing to its railing.
Before beginning this repair, disconnect the printer from its power source and make sure the print bed is cooled to room temperature.
必要な工具と部品
Unscrew the leveling wheels under the bed and remove the print bed from its brackets.
Your y-axis should now be secured without the worry of misprinted layers. Happy printing!
6 の人々がこのガイドを完成させました。
コメント 1 件
Just want to say this is by far the most helpful of all how to articles I saw to address this issue. Thank you
