はじめに
Slipper is an indoor shoe that is used every day in your household, due to how often this is used, it can easily be torn. even it can easily be bought, fixing it will be a much cheaper way and can reduce the trash of the thrown-out slipper.
this guide is aimed at helping you fix it.
必要な工具と部品
Use glue to glue up the torn part of the vamp (the top part of the shoe)
Grab a piece of cloth and measure the amount needed to fix your shoe and cut it out.
Now poke your thread over your needle
After you poke your thread into the needle, start sewing back and front, sew all the way around the cloth.
Use glue to hold the vamp and the bottom of the shoe together.
Now sew the top and bottom of the shoe together. Poke in from the side and down the bottom again and again.
This isn’t a very hard guide and can be performed by anyone who has enough time and tools to complete it.
ある他の人がこのガイドを完成しました。
