メインコンテンツにスキップ
How to Fix a T-shirt That's Too Big
必要な工具と部品
  1. How to Fix a T-shirt That's Too Big, How to Fix a T-shirt That's Too Big: 手順 1、 2の画像 1 How to Fix a T-shirt That's Too Big, How to Fix a T-shirt That's Too Big: 手順 1、 2の画像 2
    • Lay the larger T-shirt on a flat surface.
    • Make sure it sits perfectly flat and your side seams are in line.
    • Take another T-shirt that fits you perfectly and lay it on top of the larger T-shirt.
    • Double-check that the neckline is straight and the graphic on the larger T-shirt has plenty of room on either side.
  2. How to Fix a T-shirt That's Too Big: 手順 2、 1の画像 1
    • Use a water-soluble fabric marker to trace the small T-shirt out on the larger one.
    • Leave some fabric allowance in case you need to fix anything or make adjustments.
  3. How to Fix a T-shirt That's Too Big: 手順 3、 1の画像 1
    • Use scissors to cut off the excess material.
    • This will divide the shirt into three pieces: the body and two sleeves. Make sure to leave some seam allowance to make adjustments, if needed.
  4. How to Fix a T-shirt That's Too Big: 手順 4、 1の画像 1
    • Using pins, put the sleeves together in order to give a crease.
    • Pin the rest of the unsewn edges to get a rough idea of whether it is the correct size.
  5. How to Fix a T-shirt That's Too Big: 手順 5、 1の画像 1
    • Use your sewing machine to sew the parts of the shirt together.
    • Go back over with a smaller stitch to secure the parts of the shirt.
    • This guide uses white thread for visibility. Use a matching thread unless you want contrasting colors. Sew on the inside of the T-shirt to hide your seams.
  6. How to Fix a T-shirt That's Too Big: 手順 6、 1の画像 1
    • Use scissors to cut any extra threads left over from the project.
ゴール
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
lakshay
メンバー登録日: 09/26/22
185 ポイント
1ガイドが承認済み
チーム
York University, Team A-18, Morris Fall 2022 York University, Team A-18, Morris Fall 2022人のメンバー
YORK-MORRIS-F22SAG18
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 56
今までの合計 1,689
