メインコンテンツにスキップ
How to Fix a Stretched or Loose Canvas
必要な工具と部品
  1. How to Fix a Stretched or Loose Canvas, How to Fix a Stretched or Loose Canvas: 手順 1、 2の画像 1 How to Fix a Stretched or Loose Canvas, How to Fix a Stretched or Loose Canvas: 手順 1、 2の画像 2
    • Fill a spray bottle with water at room temperature.
    • In case that you do not have a spray bottle you can use a dishcloth and moisten it.
  2. How to Fix a Stretched or Loose Canvas: 手順 2、 3の画像 1 How to Fix a Stretched or Loose Canvas: 手順 2、 3の画像 2 How to Fix a Stretched or Loose Canvas: 手順 2、 3の画像 3
    • Close the spray bottle tightly.
    • Turn the nozzle to spray.
  3. How to Fix a Stretched or Loose Canvas: 手順 3、 2の画像 1 How to Fix a Stretched or Loose Canvas: 手順 3、 2の画像 2
    • Put a towel on a flat surface and lay the canvas face down on the towel.
  4. How to Fix a Stretched or Loose Canvas: 手順 4、 3の画像 1 How to Fix a Stretched or Loose Canvas: 手順 4、 3の画像 2 How to Fix a Stretched or Loose Canvas: 手順 4、 3の画像 3
    • Carefully wet the entire backside of the canvas with the spray, or press water onto the canvas with the dishcloth.
    • Only spray until it is damp. Do not soak the canvas.
    • It does not matter if the canvas is new, old, has unfinished artwork or it is completed.
  5. How to Fix a Stretched or Loose Canvas: 手順 5、 2の画像 1 How to Fix a Stretched or Loose Canvas: 手順 5、 2の画像 2
    • Turn on the dryer so warm air comes out.
  6. How to Fix a Stretched or Loose Canvas: 手順 6、 3の画像 1 How to Fix a Stretched or Loose Canvas: 手順 6、 3の画像 2 How to Fix a Stretched or Loose Canvas: 手順 6、 3の画像 3
    • Blow dry the canvas with a hair dryer on warm until it's completely dry.
    • Keep the hair dryer at least 3 to 5 inches away from the canvas.
    • Do not place the hair dryer directly on the canvas. The heat from the hair dryer can burn the canvas.
  7. How to Fix a Stretched or Loose Canvas: 手順 7、 2の画像 1 How to Fix a Stretched or Loose Canvas: 手順 7、 2の画像 2
    • Flip the canvas over and check that it is to your liking.
    • Flip the canvas again and double check.
    • Repeat the process again if the canvas is not completely fixed.
終わりに
If it does not work, you should follow another guide where plaster is used in the canvas.
作成者
1人の作成者と共同作成されました。
Eilanis
メンバー登録日: 03/18/22
145 ポイント
1ガイドが承認済み
チーム
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 37
今までの合計 2,075
