メインコンテンツにスキップ
How to Fix a Small Hole in a Sock
必要な工具と部品
  1. How to Fix a Small Hole in a Sock, How to Fix a Small Hole in a Sock: 手順 1、 3の画像 1 How to Fix a Small Hole in a Sock, How to Fix a Small Hole in a Sock: 手順 1、 3の画像 2 How to Fix a Small Hole in a Sock, How to Fix a Small Hole in a Sock: 手順 1、 3の画像 3
    • Place one end of your thread through the hole of the needle.
    • Wet the end of your thread to make it easier to go through the hole.
    • Pull your thread all the way through and match the ends of the thread together.
    • Tie a knot with the ends of your thread.
    • The needle is sharp. Handle it carefully to prevent poking your fingers or hand.
  2. How to Fix a Small Hole in a Sock: 手順 2、 2の画像 1 How to Fix a Small Hole in a Sock: 手順 2、 2の画像 2
    • Insert your tennis ball into the sock until it is lined up with the hole in your sock.
  3. How to Fix a Small Hole in a Sock: 手順 3、 3の画像 1 How to Fix a Small Hole in a Sock: 手順 3、 3の画像 2 How to Fix a Small Hole in a Sock: 手順 3、 3の画像 3
    • Insert your needle into the inside of the sock at the edge of the hole no more than half a centimeter away from the edge.
    • Pull the needle all the way through.
    • If the tail of your thread is too long, trim the excess.
  4. How to Fix a Small Hole in a Sock: 手順 4、 1の画像 1
    • Insert your needle next to and below where the first insert was.
    • Pull your needle all the way through to create your first stitch.
  5. How to Fix a Small Hole in a Sock: 手順 5、 2の画像 1 How to Fix a Small Hole in a Sock: 手順 5、 2の画像 2
    • Insert your needle in the opposite side of the hole and pull to create another stitch.
    • Repeat this step, crisscrossing your stitches until you reach the end of the hole.
    • Keep your stitches loose. You will tighten them at the end.
  6. How to Fix a Small Hole in a Sock: 手順 6、 3の画像 1 How to Fix a Small Hole in a Sock: 手順 6、 3の画像 2 How to Fix a Small Hole in a Sock: 手順 6、 3の画像 3
    • Once you reach the end of the hole, carefully pull on your thread to tighten the stitches together.
  7. How to Fix a Small Hole in a Sock: 手順 7、 2の画像 1 How to Fix a Small Hole in a Sock: 手順 7、 2の画像 2
    • To close off the stitch, insert your needle back under all of your stitches and pull out your needle at the top of the repair.
    • Pull your needle through, but not all the way, to create a small loop.
  8. How to Fix a Small Hole in a Sock: 手順 8、 2の画像 1 How to Fix a Small Hole in a Sock: 手順 8、 2の画像 2
    • Insert the needle through the small loop.
    • Pull your needle until the loop disappears.
  9. How to Fix a Small Hole in a Sock: 手順 9、 2の画像 1 How to Fix a Small Hole in a Sock: 手順 9、 2の画像 2
    • To create a final stitch, insert your needle back under all of your stitches.
    • Pull the thread all the way through.
  10. How to Fix a Small Hole in a Sock: 手順 10、 3の画像 1 How to Fix a Small Hole in a Sock: 手順 10、 3の画像 2 How to Fix a Small Hole in a Sock: 手順 10、 3の画像 3
    • Trim off the excess thread.
    • Remove the tennis ball from your sock.
ゴール
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Yuchen Xu
メンバー登録日: 02/03/23
223 ポイント
1ガイドが承認済み
チーム
UC Davis, Team 3-2, Andersen Winter 2023 UC Davis, Team 3-2, Andersen Winter 2023人のメンバー
UCD-ANDERSEN-W23S3G2
3 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 21
過去 30 日: 58
今までの合計 509
