メインコンテンツにスキップ
How to Fix a Small Ceramic Statue
必要な工具と部品
  1. How to Fix a Small Ceramic Statue, How to Fix a Small Ceramic Statue: 手順 1、 1の画像 1
    • Gather all the pieces and dust them off using the toothbrush. This way there is no stray shards left on the pieces.
  2. How to Fix a Small Ceramic Statue: 手順 2、 1の画像 1
    • Lay all the pieces on a towel or clean surface, aligned with where they belong. This way it is easy to find what you need in a timely manner.
    • This step is not required but recommended to keep all of the broken pieces organized.
  3. How to Fix a Small Ceramic Statue: 手順 3、 2の画像 1 How to Fix a Small Ceramic Statue: 手順 3、 2の画像 2
    • Using the largest piece as the base for the repair, start gluing the pieces back where they belong. Make sure to not overuse the glue, as it can cause issues later.
    • Follow the instructions for the super glue you are using, dampening areas with water if needed.
  4. How to Fix a Small Ceramic Statue: 手順 4、 1の画像 1
    • As you glue each piece make sure to hold it in place until it solidifies enough to hold everything in place, then glue on the next piece.
    • This step can vary in time. The glue I used required being held in place for a few minutes.
  5. How to Fix a Small Ceramic Statue: 手順 5、 1の画像 1
    • After you glue it back together, allow it to dry. This way the glue has time to set in place and harden.
    • Make sure your ceramic piece is somewhere stable and dry. If it is not stable it could fall and break again. If the room is not dry the glue could have issues drying properly.
  6. How to Fix a Small Ceramic Statue: 手順 6、 1の画像 1
    • Finally, lightly sand and paint the areas you glued.
ゴール
作成者
1人の作成者と共同作成されました。
Trenton Gilbert
メンバー登録日: 05/19/20
133 ポイント
1ガイドが承認済み
チーム
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 20
過去 30 日: 43
今までの合計 1,613
