メインコンテンツにスキップ
How to Fix a Skewed Wheel on a Children's Kick Scooter
必要な工具と部品
  1. How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 1、 3の画像 1 How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 1、 3の画像 2 How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 1、 3の画像 3
    • Remove the two bottom 16 mm pan head screws using a Phillips #1 screwdriver.
  2. How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 2、 3の画像 1 How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 2、 3の画像 2 How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 2、 3の画像 3
    • Remove the two 12 mm button head screws on top using a 4 mm Allen wrench.
  3. How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 3、 3の画像 1 How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 3、 3の画像 2 How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 3、 3の画像 3
    • Remove the plastic case from the base of the scooter.
  4. How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 4、 3の画像 1 How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 4、 3の画像 2 How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 4、 3の画像 3
    • Carefully pull the sides of the wheels up and remove them from the spring.
  5. How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 5、 3の画像 1 How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 5、 3の画像 2 How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 5、 3の画像 3
    • Grab the spring with combination pliers and bend it into a straight position.
    • Don't bend the spring too much as it could snap and replacement would be needed.
  6. How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 6、 3の画像 1 How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 6、 3の画像 2 How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 6、 3の画像 3
    • Insert the spring into the center section of the wheels.
    • Slide the two rings on the sides of the wheels into the two rods.
  7. How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 7、 3の画像 1 How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 7、 3の画像 2 How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 7、 3の画像 3
    • Insert the plastic case back into its original position.
  8. How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 8、 3の画像 1 How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 8、 3の画像 2 How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 8、 3の画像 3
    • Insert and tighten the two 12 mm button head screws on top using a 4 mm Allen wrench.
  9. How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 9、 3の画像 1 How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 9、 3の画像 2 How to Fix a Skewed Wheel on a Children's Kick Scooter: 手順 9、 3の画像 3
    • Replace the two bottom 16 mm pan head screws using a Phillips #1 screwdriver.
ゴール
作成者
1人の作成者と共同作成されました。
Amir Issagali
メンバー登録日: 01/10/21
169 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G14, O'Regan Winter 2021 York University, Team S1-G14, O'Regan Winter 2021人のメンバー
YORK-O'REGAN-W21S1G14
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 33
今までの合計 1,450
