はじめに
Passionate about your dog? Unable to take them out because their Flexi leash is no longer retracting? Successful maintenance of a Flexi dog leash requires knowledge of how to reuse and fix your screw-less leash. With only a screwdriver and 15 minutes of your time, you will learn how to repair the retracting mechanism in your screw-less Flexi brand retractable dog leash to make it usable. This guide will minimize waste and help you save money on buying a brand new dog leash.
必要な工具と部品
Locate the detachable T-shaped opening at the bottom of the dog leash.
Insert a pry tool into the bottom of the "T".
8 の人々がこのガイドを完成させました。
4 件のコメント
non si riavvolge più
There was a rubber o-ring that fell out of mine but I can't tell where it goes. Anyone know?
I took mine apart and put it back together, but now the only thing is it doesn’t wind the string automatically. The string will unwind and lock just fine, but it no longer pulls it back in, so the leash is stuck long unless I pull the thing apart and wind it back up manually
