メインコンテンツにスキップ
How to Fix a Ripped Shirt Hem
必要な工具と部品
  1. How to Fix a Ripped Shirt Hem, How to Fix a Ripped Shirt Hem: 手順 1、 3の画像 1 How to Fix a Ripped Shirt Hem, How to Fix a Ripped Shirt Hem: 手順 1、 3の画像 2 How to Fix a Ripped Shirt Hem, How to Fix a Ripped Shirt Hem: 手順 1、 3の画像 3
    • Turn your shirt inside out.
    • Find your shirt's ripped hem.
    • If the shirt has any loose strings, trim them.
  2. How to Fix a Ripped Shirt Hem: 手順 2、 1の画像 1
    • Iron the area of the shirt where the hem is ripped.
    • If the hem is ripped several inches, you might want to insert sewing pins to keep the fabric in place.
    • It's important to iron because it allows for easier sewing when the shirt stays folded the same way as the non-ripped part of the hem.
    • The iron will be very hot. Be careful as to not burn yourself.
  3. How to Fix a Ripped Shirt Hem: 手順 3、 1の画像 1
    • Acquire a sewing needle and thread.
    • Take your thread and loop it through the eye of the needle, the hole at the end of the needle.
    • You'll want the thread to be the same color and shade as the original thread. For visual purposes, I will use red in place of black.
    • The needle is sharp.
  4. How to Fix a Ripped Shirt Hem: 手順 4、 1の画像 1
    • Pull the thread through the needle so that there is an equal length on each side of the needle.
    • Tie the end of the thread together by making a knot.
    • Making an additional knot over the first makes it more secure.
  5. How to Fix a Ripped Shirt Hem: 手順 5、 1の画像 1
    • Starting on the inside of the shirt, poke the needle through toward the side that is right-side-out.
    • Sew over the original thread for about half an inch to ensure that it's thread won't rip again.
  6. How to Fix a Ripped Shirt Hem: 手順 6、 1の画像 1
    • Once the needle and thread is pulled through the side that is right-side-out, you will push it back through as close to the original hole as you can.
    • Doing this will make the visible hem as hidden as possible.
  7. How to Fix a Ripped Shirt Hem: 手順 7、 3の画像 1 How to Fix a Ripped Shirt Hem: 手順 7、 3の画像 2 How to Fix a Ripped Shirt Hem: 手順 7、 3の画像 3
    • When you're back on the inside of the hem, make the next stitch a couple millimeters over and diagonal from the first.
  8. How to Fix a Ripped Shirt Hem: 手順 8、 2の画像 1 How to Fix a Ripped Shirt Hem: 手順 8、 2の画像 2
    • Continue this pattern so that the inside has diagonal stitches, and the outside has small, staggered dots.
  9. How to Fix a Ripped Shirt Hem: 手順 9、 3の画像 1 How to Fix a Ripped Shirt Hem: 手順 9、 3の画像 2 How to Fix a Ripped Shirt Hem: 手順 9、 3の画像 3
    • Finish sewing the hem. Make sure the last stitch is on the inside of the shirt.
    • Make a knot where you intend for the pattern to stop.
    • It's important to tie the knot as close to the fabric as possible. Doing this secures the stitching.
  10. How to Fix a Ripped Shirt Hem: 手順 10、 1の画像 1
    • Cut off excess thread.
ゴール
5 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Kaitlyn Adams
メンバー登録日: 09/29/15
283 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 17-5, Green Fall 2015 Cal Poly, Team 17-5, Green Fall 2015人のメンバー
CPSU-GREEN-F15S17G5
4 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 42
今までの合計 12,367
