メインコンテンツにスキップ
How to Fix a Popped Rubik’s Cube
必要な工具と部品
  1. How to Fix a Popped Rubik’s Cube, How to Fix a Popped Rubik’s Cube: 手順 1、 2の画像 1 How to Fix a Popped Rubik’s Cube, How to Fix a Popped Rubik’s Cube: 手順 1、 2の画像 2
    • Place your cube down and look for the popped pieces.
    • Collect all the popped pieces and group the corners and the edges separately.
  2. How to Fix a Popped Rubik’s Cube: 手順 2、 2の画像 1 How to Fix a Popped Rubik’s Cube: 手順 2、 2の画像 2
    • Place the pieces layer by layer to make it easier to put the cube back together.
    • If only pieces that popped are from the second and third layer, start with the edges of the second layer.
  3. How to Fix a Popped Rubik’s Cube: 手順 3、 3の画像 1 How to Fix a Popped Rubik’s Cube: 手順 3、 3の画像 2 How to Fix a Popped Rubik’s Cube: 手順 3、 3の画像 3
    • Place the edges and corners that popped from the third layer.
  4. How to Fix a Popped Rubik’s Cube: 手順 4、 3の画像 1 How to Fix a Popped Rubik’s Cube: 手順 4、 3の画像 2 How to Fix a Popped Rubik’s Cube: 手順 4、 3の画像 3
    • Twist the third layer 45°.
    • Place the corners of the third and last layer.
  5. How to Fix a Popped Rubik’s Cube: 手順 5、 3の画像 1 How to Fix a Popped Rubik’s Cube: 手順 5、 3の画像 2 How to Fix a Popped Rubik’s Cube: 手順 5、 3の画像 3
    • Last but not least, place the final edge piece.
    • To make it easier to place, pull apart the two corner pieces slightly and insert the edge at an angle. Twist it a little bit until it goes in.
  6. How to Fix a Popped Rubik’s Cube: 手順 6、 3の画像 1 How to Fix a Popped Rubik’s Cube: 手順 6、 3の画像 2 How to Fix a Popped Rubik’s Cube: 手順 6、 3の画像 3
    • This last step is for cubes with this feature, like many speed cubes.
    • Remove the cap to expose the screw attached to the core.
    • You can remove the cap with your nails or any prying tool like a spudger or opening tool.
    • Tighten the loose screws. (It can be anywhere from 180° to 360°)
    • Make sure to tighten the screw enough so that it won't pop easily. Tightening the cube will make it pop less, but may make corner cutting worse. (Corner cutting allows turning with misaligned layers on speed cubes)
終わりに
This simple yet effective fix will help you prevent any future pops in your Rubik's cube. I hope this guide helped you a lot!
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Giovanni Román
メンバー登録日: 03/18/22
214 ポイント
1ガイドが承認済み
チーム
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 17
過去 7 日: 32
過去 30 日: 101
今までの合計 9,546
