はじめに
Is paper stuck in your Brother MFC-780W Printer? Don't worry, this guide provides a simple, step-by-step process to fix paper jams on the Brother MFC-780W. The guide goes over multiple ways to fix the paper jam, whether through the printer's front cover or the paper tray. To avoid having paper jams in the first place, make sure to not overload the printer with paper, as that could cause a jam in the paper tray. Also, it is best to not interrupt a printing job, as that can cause a paper jam. Make sure that you use the right paper for your printer, as using different paper sizes and thicknesses can cause the paper to be stuck when printing.
By following these steps, you should be able to fix your paper jam.
