メインコンテンツにスキップ
How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520
必要な工具と部品
  1. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520, How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 手順 1、 1の画像 1
    • Press Stop to cancel the print job.
  2. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 手順 2、 2の画像 1 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 手順 2、 2の画像 2
    • Turn off the printer.
    • Unplug your printer from the power source.
  3. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 手順 3、 2の画像 1 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 手順 3、 2の画像 2
    • Open the front tray and check for jammed paper.
    • If you don't see any jammed paper, skip to step 5.
  4. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 手順 4、 2の画像 1 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 手順 4、 2の画像 2
    • Pull the paper out slowly using both of your hands to avoid tearing.
    • If paper tears apart, do not force the paper out. You can remove any remaining paper by accessing the back panel.
    • If you were able to remove all of the jammed paper through the front, there's no need to continue! Simply proceed using your printer as normal.
  5. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 手順 5、 3の画像 1 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 手順 5、 3の画像 2 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 手順 5、 3の画像 3
    • Lay the printer on its backside to expose the bottom panel.
    • Remove the two screws holding the transport unit cover in place with a Phillips #1 screwdriver.
  6. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 手順 6、 2の画像 1 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 手順 6、 2の画像 2
    • Lift off the transport unit cover.
    • Be gentle while removing the cover. You don't want to damage it.
  7. How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 手順 7、 2の画像 1 How to Fix a Paper Jam From the Rear in a Canon Pixma TR4520: 手順 7、 2の画像 2
    • Remove any remaining paper gently either using your fingers or a pair of tweezers.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Ani Gurtsishvili
メンバー登録日: 10/20/20
235 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G98, Woodhouse Fall 2020 York University, Team S1-G98, Woodhouse Fall 2020人のメンバー
YORK-WOODHOUSE-F20S1G98
1 メンバー
3のガイドは作成済み
7 件のコメント
can you show the whole bottom without the tray being in the way? I would really appreciate!
Lex - 返信
it still has the two lights blinking
kresge - 返信
directions did not help, the yellow and ogange till blinks
kresge - 返信
it did not work
kresge - 返信
Papers stuck it won’t budge I’m underneath and it’s gripped it like a vice! Didn’t work where do we go from here this is horrible!
Leah Campbell - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 45
過去 30 日: 212
今までの合計 11,333
