メインコンテンツにスキップ
How to Fix a Misaligned Desk Drawer
必要な工具と部品
  1. How to Fix a Misaligned Desk Drawer, How to Fix a Misaligned Desk Drawer: 手順 1、 2の画像 1 How to Fix a Misaligned Desk Drawer, How to Fix a Misaligned Desk Drawer: 手順 1、 2の画像 2
    • Start by pulling the drawer out and detaching it from the hardware mounted to the desk.
    • To do this you need to push the black plastic lever up in order to disengage the drawer's hardware from the desk's hardware.
  2. How to Fix a Misaligned Desk Drawer: 手順 2、 2の画像 1 How to Fix a Misaligned Desk Drawer: 手順 2、 2の画像 2
    • In this case the hardware on the left side of the drawer is not functioning properly due to a bent metal piece.
    • Using the flat head screwdriver you can push the metal down around each ball bearing in order to allow the drawer to slide back and forth.
  3. How to Fix a Misaligned Desk Drawer: 手順 3、 2の画像 1 How to Fix a Misaligned Desk Drawer: 手順 3、 2の画像 2
    • The hardware attached to the drawer is also not functioning properly due to missing screws.
    • Use replacement screws to properly attach the hardware to the drawer and to allow it to support the drawer's weight.
    • Take a screw from the drawer to your local hardware store for help finding matching screws.
  4. How to Fix a Misaligned Desk Drawer: 手順 4、 1の画像 1
    • After attaching the hardware slide the drawer's piece into its counterpart on the desk.
    • It can be awkward to maneuver the drawer in alone. You may need to get some help for this step.
  5. How to Fix a Misaligned Desk Drawer: 手順 5、 1の画像 1
    • Enjoy your fully functioning drawer!
終わりに
作成者
4人の作成者と共同で作成されました。
Dante Mazzanti
メンバー登録日: 02/23/15
598 ポイント
3のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 21
今までの合計 16,358
