メインコンテンツにスキップ
How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i
必要な工具と部品
  1. How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i, How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 手順 1、 1の画像 1
    • When you start your engine and one of your tires is low on air pressure, a message will automatically appear on the iDrive display identifying which tire is low.
  2. How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 手順 2、 2の画像 1 How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 手順 2、 2の画像 2
    • Turn on the air compressor by switching the knob from OFF to AUTO.
  3. How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 手順 3、 1の画像 1
    • Firmly attach the tire chuck attachment to the air compressor hose.
  4. How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 手順 4、 2の画像 1 How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 手順 4、 2の画像 2
    • Remove the cap from the tire valve stem.
  5. How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 手順 5、 3の画像 1 How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 手順 5、 3の画像 2 How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 手順 5、 3の画像 3
    • Push the tire chuck onto the valve stem, making sure that it is secure, and you can hear air entering the tire.
  6. How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 手順 6、 1の画像 1
    • Remove the tire chuck from the valve stem.
    • Check the tire pressure using the tire pressure gauge by pressing the gauge onto the valve stem.
    • The tire pressure needs to be 32 psi.
    • If the tire pressure is below 32 psi, continue filling the tire with the air compressor.
    • Once the tire pressure reaches 32 psi, replace the cap back on the valve stem.
  7. How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 手順 7、 2の画像 1 How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 手順 7、 2の画像 2
    • Inside the car, using the control wheel, select Vehicle Info on the iDrive screen.
  8. How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 手順 8、 2の画像 1 How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 手順 8、 2の画像 2
    • Using the control wheel, select Vehicle Status.
    • You will see an image on the display that confirms that all four tires are at the correct pressure.
  9. How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 手順 9、 1の画像 1
    • Using the control wheel, select Perform reset.
  10. How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 手順 10、 1の画像 1
    • Drive the car to a speed of at least 20 mph until a message appears on the display that indicates that the reset is in process.
  11. How to Fix a Low Tire Pressure Monitor Warning in a BMW X3 xDrive30i: 手順 11、 1の画像 1
    • After 30 seconds of driving, you will see a new message: All Systems OK, confirming that the tire pressure reset has been successfully completed.
終わりに
Resetting your tire pressure on your BMW X3 is easy to do following these simple steps and photos.
作成者
1人の作成者と共同作成されました。
Camryn Stepp
メンバー登録日: 02/14/21
193 ポイント
1ガイドが承認済み
チーム
Texas Tech, Team S3-G6, Cowan Spring 2021 Texas Tech, Team S3-G6, Cowan Spring 2021人のメンバー
TTU-COWAN-S21S3G6
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 42
過去 30 日: 205
今までの合計 12,994
